does not a name type error
Hi guys,
I'm trying to make an analog clock with a servo motor without RTC module.
At the beginning it was all ok, but, when i tried to order the code with comments and spaces, the "does not a name type" error appears for each object. :confused:
// 22/07/2017
// ANALOG CLOCK
// *Riccardo*
//--------------library---------------\\
#include <LiquidCrystal.h> //lcd
#include <Servo.h>         //servo
#include "IRremote.h"      //IR
//------------------objects--------------------------\\
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);     //LCD pin
Servo wiper;    //servo name
int receiver = 3;    //IR receiver pin
//----------------------instances----------------------\\
IRrecv irrecv(receiver); //instance of 'irrecv'
decode_results results; //instance of 'decode_results'
//-----------variables-----------\\
int h = 5;  //ora
int m = 06;    //minuti
int s = 0;   //secondi
int flag;
int TIME;
int state1;
int state2;
//-------------------VOID SETUP------------------------------------\\
  Serial.begin(9600); //Serial port begin\\
  irrecv.enableIRIn(); // Start IR receiver \\
  lcd.begin(16, 2); //start LCD screen (16 columns, 2 rows)
  wiper.attach(6);  //start servo motor on pin 6
//----------------------VOID LOOP---------------------------------------\\
  s = s + 1; //add 1 second
  //--------------TIME---------------------------------------------------\\
  Serial.println(h ":" m ":" s); //print to serial monitor H, M, S
  //-------------AM/PM DECODER-----------\\
  if (flag < 12) Serial.println("AM");
  if (flag == 12) Serial.println("PM");
  if (flag > 12) Serial.println("PM");
  if (flag == 24)flag = 0;
  delay(1000); //delay 1 second
  //if 60 second -> add a minute\\
  if (s == 60) {
    s = 0;
    m = m + 1;
  //if 60 minute -> add an hour\\
  if (m == 60) {
    m = 0;
    h = h + 1;
    flag = flag + 1;
  //if 13 hour -> back to 1 hour
  if (h == 13)
    h = 1;
  //-------------------------END TIME------------------------------\\
  wiper.write((h * 14)); //set servo to hour
  //-----------lcd time display-----------\\
  lcd.clear();
  lcd.setCursor (1, 0);
  lcd.print("ORA");
  lcd.setCursor(6, 0);
  lcd.print("MIN");
  lcd.setCursor(12, 0);
  lcd.print("SEC") ;
  lcd.setCursor(2, 2);
  lcd.print(h);
  lcd.setCursor(7, 2);
  lcd.print(m);
  lcd.setCursor(13, 2);
  lcd.print(s);
Remove the backslashes from the ends of your comments. That escapes the newline, which causes the next line to also be part of the comment.
Ciao Riccardo : )
you have to remove \ at the end of your comments, and change this (line 66):
to this:
Serial.print(h);
Serial.print(":");
Serial.print(m);
Serial.print(":");
Serial.println(s);
pert:
Thank you...what a stupid mistake i did xD
