"Does not name a type" error. How to solve?
Hey! I had read a few posts asking about this subject, but I couldn't find the solution. I was trying to use CuHead v1 WiFi Shield to send a GET request to my local server, but looks like the library and the examples isn't working properly. Here follows the code:
ArduinoCode.pde
 * A simple sketch that uses WiServer to get the hourly weather data from LAX and prints
 * it via the Serial API
#include <WiShield.h>
#include <WiServer.h>
#define WIRELESS_MODE_INFRA	1
#define WIRELESS_MODE_ADHOC	2
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,1,2};	// IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1};	// router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};	// subnet mask for the local network
const char ssid[] PROGMEM = {"MY SSID NETWORK"};		// max 32 bytes
unsigned char security_type = 3;	// 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const char security_passphrase[] PROGMEM = {"MYPASSWORD"};	// max 64 characters
// WEP 128-bit keys
// sample HEX keys
const char PROGMEM wep_keys[] PROGMEM = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,	// Key 0
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	// Key 1
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,	// Key 2
				  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00	// Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters ----------------------------------------
// Function that prints data from the server
void printData(char* data, int len) {
  // Print the data returned by the server
  // Note that the data is not null-terminated, may be broken up into smaller packets, and
  // includes the HTTP header.
  while (len-- > 0) {
    Serial.print(*(data++));
// IP Address for www.weather.gov
uint8 ip[] = {192,168,1,2};
// A request that gets the latest METAR weather data for LAX
GETrequest getWeather(ip, 80, "localhost", "/index.php?id=1");
    // Initialize WiServer (we'll pass NULL for the page serving function since we don't need to serve web pages)
  WiServer.init(NULL);
  // Enable Serial output and ask WiServer to generate log messages (optional)
  Serial.begin(57600);
  WiServer.enableVerboseMode(true);
  // Have the processData function called when data is returned by the server
  getWeather.setReturnFunc(printData);
// Time (in millis) when the data should be retrieved
long updateTime = 0;
void loop(){
  // Check if it's time to get an update
  if (millis() >= updateTime) {
    getWeather.submit();
    // Get another update one hour from now
    updateTime += 1000 * 60 * 60;
  // Run WiServer
  WiServer.server_task();
  delay(10);
WiServer.h
WiServer.cpp
This code give me this errors:
ArduinoCode.pde:57:1: error: 'GETrequest' does not name a type
ArduinoCode.pde: In function 'void setup()':
ArduinoCode.pde:69:3: error: 'getWeather' was not declared in this scope
ArduinoCode.pde: In function 'void loop()':
ArduinoCode.pde:80:5: error: 'getWeather' was not declared in this scope
I had to paste the code into PasteBin because of the 900 characters limit of the forum.
Which direcory are the library files installed in ?
Did you stop and restart the IDE after installing them ?
UKHeliBob:
The library directory is /usr/share/arduino/libraries/ZG2100BasedWiFiShield
I did stop and restart the IDE after installing.
The library directory is arduino/libraries/library_folder
You aren't using a library called library_folder. When asked for the library path, we mean the EXACT path of the library in question.
I don't do rubbish bin. Attach your code properly, using the Additional Options... link, or I'll move on.
PaulS:
I tryed to attach my code properly, but the forum didn't allow me to save my post!
That's why the program can't find the libraries. The folder name must match that of the library it contains.
UKHeliBob:
I renamed the folder to "WiServer", but nothing changed. The errors keep coming. I already use part of this library in another project, but I had to modify a lot of the code to avoid some errors.. I haven't changed anything in this part of the code or its dependencies...
