Does Not Name a Type Error
Hi, I have searched for an answer for this error and there definitely are some topics on it, just none have worked for me.
The program will eventually be part of a bigger program that has 3 different height buttons and a button to ‘set’ each height.
4 buttons, 4 LED’s indicating which button you’ve pressed.
Just got a program working for 1 button and LED to make the LED stay lit even after the button has been let go.
I then copied and pasted the code and changed the names to do it for a second LED but it threw this error up.
I will also want to eventually make the LED of the current button turn off when a new LED is pressed if anyones any suggestions
I’m a complete novice and have next to no experience programming so excuse the shoddiness.
Thank you in advance.
const int SetButtonPin = 16;
const int LowButtonPin = 17;
const int MedButtonPin = 18;
const int HighButtonPin = 19;
const int SetLEDPin = 13;
const int LowLEDPin = 2;
const int MedLEDPin = 8;
const int HighLEDPin = 7;
int SetButtonState = 1;
int LowButtonState = 1;
int MedButtonState = 1;
int HighButtonState = 1;
int SetButtonPushCounter = 0;
int SetLastButtonState = 0;
int LowButtonPushCounter = 0;
int LowLastButtonState = 0;
int MedButtonPushCounter = 0;
int MedLastButtonState = 0;
int HighButtonPushCounter = 0;
int HighLastButtonState = 0;
int SetLEDState = 0;
int LowLEDState = 0;
int MedLEDState = 0;
int HighLEDState = 0;
boolean flag = true;
unsigned long LastSetDebounceTime = 0;
unsigned long LastLowDebounceTime = 0;
unsigned long LastMedDebounceTime = 0;
unsigned long LastHighDebounceTime = 0;
unsigned long debounceDelay = 50;
pinMode (SetButtonPin,INPUT_PULLUP);
pinMode (LowButtonPin, INPUT_PULLUP);
pinMode (MedButtonPin, INPUT_PULLUP);
pinMode (HighButtonPin, INPUT_PULLUP);
pinMode (SetLEDPin, OUTPUT);
pinMode (LowLEDPin, OUTPUT);
pinMode (MedLEDPin, OUTPUT);
pinMode (HighLEDPin, OUTPUT);
digitalWrite(LowLEDPin, LowButtonPin);
  // Start of Set button Working;
  int reading = digitalRead(SetButtonPin);
SetButtonState = digitalRead(SetButtonPin);
if (reading != SetLastButtonState) {
  LastSetDebounceTime = millis();
if ((millis() - LastSetDebounceTime) > debounceDelay) {
  if(reading != SetButtonState) {
    SetButtonState = reading;
    if (SetButtonState == HIGH) {
      SetButtonState = !LowLEDState;
if (digitalRead(SetButtonPin)==LOW){
  delay(5);
      flipflop();
  // other sketch code here
} // end of main loop.
void flipflop(){
  flag = !flag;
  Serial.print("flag =   " );   Serial.println(flag);
  if (flag == HIGH){
    digitalWrite(SetLEDPin,HIGH );
  if (flag == LOW) {
    digitalWrite(SetLEDPin,LOW);
  while(digitalRead(SetButtonPin)==LOW);
  delay(50);
 // Start of Low button Working;
  int reading = digitalRead(LowButtonPin);
  LowButtonState = digitalRead(LowButtonPin); //This is where the Error is.
if (reading != LowLastButtonState) {
  LastLowDebounceTime = millis();
if ((millis() - LastLowDebounceTime) > debounceDelay) {
  if(reading != LowButtonState) {
    LowButtonState = reading;
    if (LowButtonState == HIGH) {
      LowButtonState = !LowLEDState;
if (digitalRead(LowButtonPin)==LOW){
  delay(5);
      flipflop();
void flipflop(){
  flag = !flag;
  if (flag == HIGH){
    digitalWrite(LowLEDPin,HIGH );
  if (flag == LOW) {
    digitalWrite(LowLEDPin,LOW);
  while(digitalRead(LowButtonPin)==LOW);
  delay(50);
You've made copy/paste errors
As a result, a lot of statements are outside functions. Check the part after the end of the first flipflop() function.
