Hi there, I'm having trouble resolving an issue with compiling my code. I am extremely new at this so it could be a trivial issue.
I am using the CTC 101 kit with an Arduino UNO for tutorials with the education shield piece which can be added onto the top of the UNO, and I am on a OSX. From what I can tell this is a library issue but I am unsure on how to fix it.
The error i am getting is "Does not name a type", here is an example from the 5.1 tutorial
exit status 1
'IMU' does not name a type
Here is the code provided by the tutorial on the website, however the issue is with defining the IMU with the 4th line "IMU imu;"
#include <EducationShield.h>
IMU imu; // the IMU
const int piezoPin = 8; //piezo
const int ledPin = 13; // activity LED pin
boolean blinkState = false; // state of the LED
// configure Arduino LED for activity indicator
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); // turn on LED to show that the board has executed
Serial.begin(9600); // initialize Serial communication
while (!Serial); // wait for the serial port to open
imu.begin();
// blink the LED again to show that the calibration is done
blinkState = !blinkState;
digitalWrite(ledPin, blinkState);
pinMode(piezoPin, OUTPUT);
// start the IMU read
imu.run();
// read raw gyro measurements from the IMU device
int gx = imu.getGyroX();
int gy = imu.getGyroY();
// map the raw value to be on a smaller scale
gx = map(gx, -36044 , 36043 , -360, 360);
gy = map(gy, -36044 , 36043 , -360, 360);
// print the measurements
Serial.print(gx);
Serial.print("\t");
Serial.println(gy);
//Computes the absolute value of the IMU read
gx = abs(gx);
gy = abs(gy);
// add together the 2 values and use them for setting the frequency for the speaker to play
int frequency = gx + gy;
frequency = frequency / 2;
frequency = map(frequency, 0, 360, 0, 1000);
// only play a sound if the frequency is not too low or the IMU is still
if (frequency > 50) {
tone(piezoPin, frequency);
noTone(piezoPin);// stop the sound
// blink LED to indicate activity
delay(30);
From everything I've been able to find, this is an issue with the library it includes from, but i have the correct library provided and I believe it is in the correct folder (Documents/Arduino/libraries).
This is my first time posting. sorry if I missed anything.
