retrolefty:
[quote author=Nick Gammon link=topic=143876.msg1080713#msg1080713 date=1358717944]
OK, well we have two issues here. First is getting the bootloader onto the chip, which can be a problem with some programmers with > 64K words of program memory.
The second is, to have a bootloader that itself can handle the extra memory itself (effectively the same problem, moved to the bootloader).
I have seen so many incarnations of bootloaders, I am unsure which one work absolutely correctly. I believe the one which my bootloader-installer installs works correctly, but haven't tried a very large sketch (with that bootloader). I have tested the WDT issue though.
After much searching yesterday and today I finally located a optiboot hex file compiled for a mega1280 board in someone's site. I just was able to burn it into two different mega1280 boards I have using arduinoISP sketch from IDE 1.0.3 as the programmer type and they both took the new optibootloader without error. I tested both with a WDT testing sketch that would 'brick' a mega board with it's original bootloader, but now function correctly, so yea.
So the present arduinoISP programmer sketch has no issues burning bootloaders into large memory AVR chips.
So if anyone else is having trouble finding a optiboot for a mega1280 chip I will post it here:
:020000000404F6
:020000021000EC
:10FC0000112484B714BE81FFF2D085E08093810077
:10FC100082E08093C00088E18093C10086E08093F9
:10FC2000C20080E18093C4008EE0CBD0279A86E0AA
:10FC300020E33CEF91E0309385002093840096BB55
:10FC4000B09BFECF1F9AA8958150A9F7CC24DD2444
:10FC500099249394A5E0BA2EF1E1AF2EA6D0813479
:10FC600061F4A3D0082FB3D0023811F0013811F499
:10FC700084E001C083E091D08DC0823411F484E12E
:10FC800003C0853419F485E0AAD084C08535A1F479
:10FC90008CD0082F10E089D0E82EFF24FE2CEE2413
:10FCA000E02AF12A8F2D881F8827881F8BBFEE0C32
:10FCB000FF1C8DD067016EC0863521F484E08FD0A3
:10FCC00080E0D9CF843609F042C06FD06ED0082FC3
:10FCD0006CD080E0C81680EED80620F483E0F601F0
:10FCE00087BFE895C0E0D2E060D089930C17E1F7B8
:10FCF000F0E0CF16F0EEDF0620F083E0F60187BFDC
:10FD0000E89565D007B600FCFDCFA601A0E0B2E003
:10FD10002C9130E011968C91119790E0982F8827C4
:10FD2000822B932B1296FA010C0197BEE8951124B1
:10FD30004E5F5F4FF3E0A030BF0751F7F601B7BE4B
:10FD4000E89507B600FCFDCFA7BEE89523C0843731
:10FD5000A1F42BD02AD0E82E28D039D0E6010E2DE0
:10FD6000FE0186911AD021960150D1F70894C11C4A
:10FD7000D11CEA94CE0CD11C0DC0853731F427D0AC
:10FD80008EE10BD087E909D075CF813511F488E079
:10FD900018D01DD080E101D061CF982F8091C00094
:10FDA00085FFFCCF9093C60008958091C00087FF27
:10FDB000FCCF8091C00084FD01C0A8958091C60051
:10FDC0000895E0E6F0E098E1908380830895EDDF08
:10FDD000803219F088E0F5DFFFCF84E1DECF1F939A
:10FDE000182FE3DF1150E9F7F2DF1F91089580E04B
:08FDF000E8DFEE27FF2709946C
:040000031000FC00ED
:00000001FF
I also had to create a new board entry for the boards.txt file in the arduino core:
megao.name=Arduino Mega1280 Optiboot
megao.upload.protocol=arduino
megao.upload.maximum_size=130048
megao.upload.speed=115200
megao.bootloader.low_fuses=0xff
megao.bootloader.high_fuses=0xda
megao.bootloader.extended_fuses=0xf5
megao.bootloader.path=optiboot
megao.bootloader.file=optiboot_atmega1280.hex
megao.bootloader.unlock_bits=0x3F
megao.bootloader.lock_bits=0x0F
megao.build.mcu=atmega1280
megao.build.f_cpu=16000000L
megao.build.core=arduino
megao.build.variant=mega
And finally a WDT testing sketch that someone on this forum wrote that works fine on a Uno type board but WILL BRICK any arduino mega1280/2560 board that hasn't been upgraded with the opitboot bootloader, so only run it if you know what your are doing and have the means to reburn the bootloader to recover.
// Test sketch to see if WDT interrupts are handled properly by the bootloader
Warning Warning Warning this is a semi-destructive test in that
if your bootloader does not reset WDT interrupts upon starting
it will be forced into a tight loop of bootloader starts/WDT resets
chip/bootloader starts again/lather rinse repeat. One can only
recover to normal operation by reburning the bootloader with
a ICSP programmer. If this sketch runs properly on a chip with a WDT aware bootloader,
you will see continous serial output on the serial monitor.
Note that current arduino mega boards will fail this test and brick
// Code from arduino forum poster (sorry name not remembered) 1/11/13
#include <avr/wdt.h>
void setup(){
Serial.begin(57600);
delay(100);
Serial.println("Hello world");
wdt_enable(WDTO_15MS);
void loop(){
Serial.println("I am going to not get stuck..");
for(int x=0; x<100; x++) {
wdt_reset();
x++;
delay(10);
wdt_reset();
Serial.println("I am going to get stuck now..");
for(int x=0; 1; x++) {
delay(10);
Lefty
[/quote]
