system
April 7, 2012, 1:30pm
1
if available() gets the number of bytes arrived and stored in the serial recieve buffer, how come the result of the code bellow is just printing.
(when i lunch the program, the result on the serial monitor is: printprintprintprintprint....)
char inByte = 0;
void setup (){
void loop ()
Serial.print("print");
while (Serial.available()>0){
inByte = Serial.read();
Serial.print(inByte);
What should i do program to stop after serial.print("print")
(print and then wait till you recieve at least 1 byte)
thank you very much
system
April 7, 2012, 1:35pm
2
If you are sending nothing to the serial port, the while loop has no affect, so your program is equivalent to:
void setup (){
void loop ()
Which should make it pretty obvious why it keeps printing "print" over and over.
system
April 7, 2012, 2:51pm
3
PaulS:
void setup (){
void loop ()
Do you maybe know, what should i do program to stop after print() and wait for some incoming byte from serial monitor and then go on?
cmiyc
April 7, 2012, 3:23pm
4
difenbahij:
change your while statement.
Edit: Incorrect code removed. Thanks Paul
system
April 7, 2012, 3:27pm
5
difenbahij:
char inByte = 0;
void setup (){
void loop ()
thank you very much
char inByte;
if (Serial.available())
///if there's nothing there, it will loop and start again, it does not 'wait' it simply gives yes/no answer and then you get the data.
system
April 7, 2012, 3:38pm
6
tnx, but
void loop(){
Serial.print("text");
if (Serial.available()){
also prints "text" over and over again
char inByte = 0;
void setup (){
void loop ()
Serial.print("print ");
while (Serial.available()==0)
; // Do nothing
Serial.println(inByte);
system
April 8, 2012, 12:59am
8
while (Serial.available()<=0){ // waits until a byte is sent
Come on, James. You know better than that. While there is nothing to read, read it?
cmiyc
April 8, 2012, 1:10am
9
PaulS:
Well gee, when you put it that way, the whole loop looks kinda silly, doesn't it?
