Does softwareSerial recognise available()?
Hi all,
I am getting conflicting answers in searching and reading about using available() with softwareSerial?
Could anyone enlighten me as to the truth. Can you use for instance:
if(mySerial.available()){
//do stuff here
cheers
Larp-fx:
Hi all,
//do stuff here
cheers
yes SoftwareSerial inherits from Stream
Excellent,
cheers
(deleted)
I did try it first, couldn’t get it to work so did some research to see if I could find the problem / solution.
I still can’t get this simple receiver for a HC12 module to work however.
So any tips would be great.
#include <SoftwareSerial.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
SoftwareSerial MySerial(4, 5); // RX, TX
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
  MySerial.begin(9600); //begins HC-12 to receive serial data
  Serial.begin(9600); //begins PC serial data
  display.begin();
  display.setTextColor(WHITE);
  display.clearDisplay();
  display.setTextSize(1);
  display.setCursor(0, 0);
  display.println("Ready to receive");
  display.display();
  if(MySerial.available() ){//Read from HC-12 and send to OLED
     String input = MySerial.readString();//Get string from HC-12, store as "input"
      display.setCursor(0, 20);
      display.println(input);//Prints the string "recieve" onto the OLED"
      Serial.println(input);//print to the monitor also to check
      display.display();
Larp-fx:
I still can't get this simple receiver for a HC12 module to work however.
I wonder if sharing pin4 has anything to do with it...
Have you tried printing MySerial.available() ?
What does the 4 here relate to ?
Hi chaps,
TBH I am not sure what that OLED_RESET 4 means, as I just copied that across from some other code. I assumed, probably wrongly that it was needed.
I have changed it to an unused digital Pin.
Still no luck though.
I tried printing MySerial.available and that does nothing?
cheers
Larp-fx:
It didn't print anything at all? Well you must have done it wrong. Why don't you post that code and let's see what you did wrong.
Larp-fx:
I assumed
Assumption is the mother of all f&%k-ups. When you don't understand something like that, then it is time to take a step back and do some learning.
