i am using rotary encoder , sd and ps2 controller.
as spi communication disables interrupts several times does this will effect my encoder reading.?
varangupta:
i am using rotary encoder , sd and ps2 controller.as spi communication disables interrupts several times does this will effect my encoder reading.?
Not enough information. For instance where is the code that's doing this?
Why would you disable interrupts to read SPI anyway?
unsigned char PS2X::_gamepad_shiftinout (char byte) {
uint8_t old_sreg = SREG; // *** KJE *** save away the current state of interrupts
unsigned char tmp = 0;
cli(); // *** KJE *** disable for now
for(i=0;i<8;i++) {
if(CHK(byte,i)) SET(*_cmd_oreg,_cmd_mask); //this sets cmd bit by bit according to value in byte
else CLR(*_cmd_oreg,_cmd_mask);
CLR(*_clk_oreg,_clk_mask); //clk is pulled low before recieving the data
SREG = old_sreg; // *** *** KJE *** *** Interrupts may be enabled again
delayMicroseconds(CTRL_CLK);
if(CHK(*_dat_ireg,_dat_mask)) SET(tmp,i); //this check the recieved data bit by bit and store is to temp
SET(*_clk_oreg,_clk_mask); //after recieving clk is pulled up
delayMicroseconds(CTRL_BYTE_DELAY);
return tmp;
cli(); is used several times
PS2X_lib.cpp (23.6 KB)
Well I see no reason for it, SPI is not a synchronous protocol.
Same issue here. I am using an arduino Pro Micro and interrupt 0 on pin 3. If I don't use SPI the interrupt works fine, otherwise it ignores the interrupt. Here is my code.
#include <SPI.h>
const byte interruptPin = 3;
const byte clk = 15, data = 16, latch = 5, ledpin = 17, nr_inputs = 4;
byte z = 0;
pinMode(clk, OUTPUT);
pinMode(data, OUTPUT);
pinMode(latch, OUTPUT);
pinMode(interruptPin, INPUT);
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.begin();
attachInterrupt(0, sh_reg_int, RISING);
SPI.transfer(3);
SPI.transfer(255);
digitalWrite(latch, 1);
digitalWrite(latch, 0);
void sh_reg_int(){
for(int i=0; i<3; i++){
bitWrite(z,i,!bitRead(z,i));
SPI.transfer(z);
SPI.transfer(255);
