I have m2tklib set up with a DOGL128 LCD (64x128, resistive touchscreen, uses u8glib). It's working fine with the touchscreen examples, so I know I have things wired up properly and the library set up and working.
I modified the Touchpanel example code to use a GRIDLIST instead of VLIST, and that worked fine.
I'm now trying to get dynamic menus working. The way the example code is written, the menu strings are all hard-coded. To get a dynamic string, it looks like I will need to use something like STRLIST.
Problem is, the STRLIST examples all use the button-based inputs. I'm trying to use the touchpad input and having limited success.
I modified the constructor call to use the touchpad event handler and event source handlers: m2_es_touch_screen and m2_eh_ts (also tried m2_eh_6bsts and m2_eh_4bsts). I'm seeing the cursor registering on the screen when I press, but the UI is nonfunctional.
Does SRTLIST not work with a touchscreen input? Or am I missing something critical with how to use the different input types? Thanks for any help!
EDIT TO ADD:
I made a little progress when I found the Touchscreen Tutorial here: Google Code Archive - Long-term storage for Google Code Project Hosting.
I still do not have it working, however. I'm thinking that perhaps the VSB element does not work well with a touchscreen, either, as there's only an increment and no decrement
Touch screen support has been added to m2tklib recently and it has not been tested so much. In fact, i never thought about STRLIST while implementing touch screen support. VSB on the other hand is a pure read only element. It does not receive any input.
As of now i suggest to use TSK elements to move the cursor up and down (as described in the touch screen tutorial).
I was just coming back to update that I did exactly that - implemented touchscreen buttons for UP/DOWN/SELECT and got rid of the VSB. The only thing that is not intuitive is that the list itself cannot be tapped to select an item - you have to scroll to it and then press the select button. Thanks for the fast update!
I try to make STRLIST aware of the "t1" option for the next release. Still you need the TSK elements to scroll to elements, which are not visible on the screen. I mean, once implemented "t1" will only apply to the visible elements of STRLIST. I do not have a good idea how to solve this without TSK elements...
olikraus:
Makes sense. That seems like it would cover most use cases pretty well, and I think it would be pretty intuitive for a user that tries to tap on an item in a list. When the list is > 1 item long, anyway. If only 1 item is shown, somebody might think that tapping on it would be what allows them to change it, rather than selecting it.
What I have right now is a 4-line STRLIST with a PREV, NEXT, and SELECT button to the right. The PREV and NEXT buttons scroll one item at a time. Since this is the only way to select an item, this makes perfect sense. When STRLIST becomes t1-aware, it might make sense for the NEXT/PREV buttons to be able to do a page-up/page-down function, since you can already select any of the 4 visible elements by tapping. I'm not sure if this would be possible/easy at all, I'm just speaking from a UI standpoint. Maybe there's a way to link an element to a variable to increment/decrement the _first variable by the height of STRLIST?
