does such code exist??
hello guys!
i am wondering if this is possible
any help is greatly appreciated :slight_smile:
normally the code goes through loop until it pauses and executes code X
for example
void loop(
doing code A
pause
execute code X //when it finishes, it returns to where it stopped and continue
unpause
continue code A
pause
unpause
continue code A
pause
..........................keep repeating....
is this possible?? the "X" code would be separately located in the code
the important this is after executing the code "X" it has to return to the
exact point where code "A" stopped
any help is greatly appreciated!!
It is called a "function".
loop()
      runA();
      executeX();
void runA()
//do a bunch of stuff
void executeX()
//do some other stuff
http://playground.arduino.cc/Code/Function
luv you guys! thanks a million!! :slight_smile:
Since you're talking about "pausing" Code A, it sounds more like you need Code X to be contained in an interrupt.
What would be triggering Code X to run? That would determine the interrupt you use (timer, external, etc.).
You may find some useful stuff in Planning and Implementing a Program
It illustrates the use of functions and the use of millis() to manage timing without blocking.
...R
I doubt he want's to use an interrupt. Just don't execute it if you want to "pause" it.
loop(){
  if(doIneedToExecuteA){
    runA();
  executeX();
void runA(){
void executeX(){
