I want to take full advantage of the sensitivity of a photodiode, which currently outputs a max voltage reading of 100/1023 via the analogRead() function.
To do so, I've reduced the reference voltage from 5V (DEFAULT) to 1.1V (INTERNAL). Since the ATMEGA328P A/D converter has a variable reference voltage capability, I assume that the full scale 0-1023 will correspond to 0-1.1V readings.
I was right, except now the resolution in the A/D output has decreased: the photodiode output is now in multiples of 32, making me feel that perhaps the same 5V reference is being used, but the output is simply scaling by 1.1/5, and no significant change has actually happened.
Am I right?
