Does the cortex m3 have usb capabilities?
Can I use this processor for a usb boot loader instead of using icsp connectors? http://uk.farnell.com/stmicroelectronics/stm32f103cbt6/mcu-32bit-cortex-m3-72mhz-lqfp/dp/1606327
Thanks!
Do not cross-post!
"Cortex m3" is a microcontroller architecture, not a specific chip. Whether it has USB or not depends on exactly which chip you have. The stm32f103cbt6 DOES have USB, and can support a USB bootloader, mostly. (It has a built-in serial bootloader, and you can make a user-programmed USB bootloader, but it's a bit tricky.)
See https://github.com/rogerclarkmelbourne/Arduino_STM32/wiki
westfw: "Cortex m3" is a microcontroller architecture, not a specific chip. Whether it has USB or not depends on exactly which chip you have. The stm32f103cbt6 DOES have USB, and can support a USB bootloader, mostly. (It has a built-in serial bootloader, and you can make a user-programmed USB bootloader, but it's a bit tricky.)
ok thanks for your reply:)
