Does the Nano RP2040 support OTA?
Want to use WiFi as bootloader. Does it supported?
I have try the Arduino OTA examples and they dont Work, as internal Storage is not supported.
Have also looked at the library files, but can not find a way to make it Work.
Im used to the esp32 boards, ejere OTA Works very well.
So expect it to work, one day, on Arduino Nano 2040 Connect, as without OTA the WiFi is very limited.
Welcome to the forum.
This is a new board and a new chip that is used by different companies. I is likely there will be more support coming in the future.
Why do you say that? You can use the board and WiFi without OTA.
You might be interested to take a look at the draft work on adding Arduino IoT Cloud OTA support for the Nano RP2040 Connect:
Thanks
Waiting for the board shipment soon. Will update if success.
When you have build in wifi and Play well for it, you expect OTA to Work. Most solutions with WiFi is place far away from a computer and without WiFi you have to collet Them All for upgrade.
