Does the Teensy Audio System Design Tool work with a Nano
Im new to all this so please excuse if it an obvious question.
Does the Teensy Audio System Design Tool work with a Nano......Create a code block using the design tool and drop it into an Arduino sketch and it sort out all the sound parameters in a stroke.
Im hoping to make a few synth modules and its super simple using Mozzi but I cant seem to find a yes or no answer and Teensys are so much more expensive.
The Teensy audio library is only usable on certain ARM architectures as it heavily uses ARM DSP instructions, so any AVR based Arduino cannot use it at all. Including early Teensy's. Basically Teensy 3.x and 4.x are supported - presumably it can be made to work on other ARM based chips too, if someone puts the work in.
