Does the UNO has survival memory?
The OLED displayed shown some thing can't understandable, say shown_a=AA; modified the code and shown_b=AB; then modified back to original, and the shown_c should be =AA, but still got AB? why?
Sorry for lack of code, if I can get answer for the "survival memory" is OK.
No code = no idea what you are talking about = no answer possible
Are you talking about non-volatile memory?
Yes, it is called EEPROM.
Thanks.
can the OLED text size be set decimal?
say: display.setTextSize(1.5);
No, it can't
No need to be sorry. Just post it, using code tags when you do
The code:
  //       Arduino Rotary Encoder Menu        //
 //                 v1.0                     //
//           http://www.educ8s.tv           //
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
#include <ClickEncoder.h>
#include <TimerOne.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO:       A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO:   2(SDA),  3(SCL), ...
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int menuitem = 1;
int frame = 1;
int page = 1;
int lastMenuItem = 1;
String menuItem1 = "Contrast";
String menuItem2 = "Volume";
String menuItem3 = "Language";
String menuItem4 = "Difficulty";
String menuItem5 = "Light: ON";
String menuItem6 = "Reset";
boolean backlight = true;
int contrast=60;
int volume = 50;
String language[3] = { "EN", "ES", "EL" };
int selectedLanguage = 0;
String difficulty[2] = { "EASY", "HARD" };
int selectedDifficulty = 0;
boolean up = false;
boolean down = false;
boolean middle = false;
ClickEncoder *encoder;
int16_t last, value;
///// Adafruit_PCD8544 display = Adafruit_PCD8544( 5, 4, 3); //Download the latest Adafruit Library in order to use this constructor
  pinMode(7,OUTPUT);
  turnBacklightOn();
  encoder = new ClickEncoder(A1, A0, A2);
  encoder->setAccelerationEnabled(false);
  display.begin();
  display.clearDisplay();
  setContrast();
  Timer1.initialize(1000);
  Timer1.attachInterrupt(timerIsr);
  last = encoder->getValue();
  drawMenu();
  readRotaryEncoder();
   ClickEncoder::Button b = encoder->getButton();
   if (b != ClickEncoder::Open) {
   switch (b) {
      case ClickEncoder::Clicked:
         middle=true;
  if (up && page == 1 ) {
    up = false;
    if(menuitem==2 && frame ==2)
      frame--;
     if(menuitem==4 && frame ==4)
      frame--;
      if(menuitem==3 && frame ==3)
      frame--;
    lastMenuItem = menuitem;
    menuitem--;
    if (menuitem==0)
      menuitem=1;
  }else if (up && page == 2 && menuitem==1 ) {
    up = false;
    contrast--;
    setContrast();
  else if (up && page == 2 && menuitem==2 ) {
    up = false;
    volume--;
  else if (up && page == 2 && menuitem==3 ) {
    up = false;
    selectedLanguage--;
    if(selectedLanguage == -1)
      selectedLanguage = 2;
    else if (up && page == 2 && menuitem==4 ) {
    up = false;
    selectedDifficulty--;
    if(selectedDifficulty == -1)
      selectedDifficulty = 1;
  if (down && page == 1) //We have turned the Rotary Encoder Clockwise
    down = false;
    if(menuitem==3 && lastMenuItem == 2)
      frame ++;
    }else  if(menuitem==4 && lastMenuItem == 3)
      frame ++;
     else  if(menuitem==5 && lastMenuItem == 4 && frame!=4)
      frame ++;
    menuitem++;
    if (menuitem==7)
      menuitem--;
  }else if (down && page == 2 && menuitem==1) {
    down = false;
    contrast++;
    setContrast();
  else if (down && page == 2 && menuitem==2) {
    down = false;
    volume++;
   else if (down && page == 2 && menuitem==3 ) {
    down = false;
    selectedLanguage++;
    if(selectedLanguage == 3)
  else if (down && page == 2 && menuitem==4 ) {
    down = false;
    selectedDifficulty++;
    if(selectedDifficulty == 2)
  if (middle) //Middle Button is Pressed
    middle = false;
    if (page == 1 && menuitem==5) // Backlight Control
      if (backlight)
        backlight = false;
        menuItem5 = "Light: OFF";
        turnBacklightOff();
        backlight = true;
        turnBacklightOn();
    if(page == 1 && menuitem ==6)// Reset
      resetDefaults();
    else if (page == 1 && menuitem<=4) {
      page=2;
      else if (page == 2)
      page=1;
  void drawMenu()
  if (page==1)
    display.setTextSize(1);
    display.setTextColor(BLACK, WHITE);
    display.setCursor(15, 0);
    display.print("MAIN MENU");
    display.drawFastHLine(0,10,83,BLACK);
    if(menuitem==1 && frame ==1)
      displayMenuItem(menuItem1, 15,true);
      displayMenuItem(menuItem2, 25,false);
      displayMenuItem(menuItem3, 35,false);
    else if(menuitem == 2 && frame == 1)
      displayMenuItem(menuItem1, 15,false);
      displayMenuItem(menuItem2, 25,true);
    else if(menuitem == 3 && frame == 1)
      displayMenuItem(menuItem3, 35,true);
     else if(menuitem == 4 && frame == 2)
      displayMenuItem(menuItem2, 15,false);
      displayMenuItem(menuItem3, 25,false);
      displayMenuItem(menuItem4, 35,true);
      else if(menuitem == 3 && frame == 2)
      displayMenuItem(menuItem3, 25,true);
      displayMenuItem(menuItem4, 35,false);
    else if(menuitem == 2 && frame == 2)
      displayMenuItem(menuItem2, 15,true);
    else if(menuitem == 5 && frame == 3)
      displayMenuItem(menuItem3, 15,false);
      displayMenuItem(menuItem4, 25,false);
      displayMenuItem(menuItem5, 35,true);
    else if(menuitem == 6 && frame == 4)
      displayMenuItem(menuItem4, 15,false);
      displayMenuItem(menuItem5, 25,false);
      displayMenuItem(menuItem6, 35,true);
      else if(menuitem == 5 && frame == 4)
      displayMenuItem(menuItem5, 25,true);
      displayMenuItem(menuItem6, 35,false);
      else if(menuitem == 4 && frame == 4)
      displayMenuItem(menuItem4, 15,true);
    else if(menuitem == 3 && frame == 3)
      displayMenuItem(menuItem3, 15,true);
      displayMenuItem(menuItem5, 35,false);
    else if(menuitem == 4 && frame == 3)
      displayMenuItem(menuItem4, 25,true);
    display.display();
  else if (page==2 && menuitem == 1)
   displayIntMenuPage(menuItem1, contrast);
  else if (page==2 && menuitem == 2)
   displayIntMenuPage(menuItem2, volume);
   else if (page==2 && menuitem == 3)
   displayStringMenuPage(menuItem3, language[selectedLanguage]);
  else if (page==2 && menuitem == 4)
   displayStringMenuPage(menuItem4, difficulty[selectedDifficulty]);
  void resetDefaults()
    contrast = 60;
    volume = 50;
    setContrast();
    backlight = true;
    turnBacklightOn();
  void setContrast()
 /////   display.setContrast(contrast);
    display.display();
  void turnBacklightOn()
    digitalWrite(7,LOW);
    void turnBacklightOff()
    digitalWrite(7,HIGH);
  void timerIsr() {
  encoder->service();
void displayIntMenuPage(String menuItem, int value)
    display.print(menuItem);
    display.setCursor(5, 15);
    display.print("Value");
    display.setTextSize(2);
    display.setCursor(5, 25);
    display.print(value);
    display.display();
void displayStringMenuPage(String menuItem, String value)
    display.display();
void displayMenuItem(String item, int position, boolean selected)
    if(selected)
      display.setTextColor(WHITE, BLACK);
    }else
    display.setCursor(0, position);
    display.print(">"+item);
void readRotaryEncoder()
  value += encoder->getValue();
  if (value/2 > last) {
    last = value/2;
    down = true;
    delay(150);
  }else   if (value/2 < last) {
    last = value/2;
    up = true;
    delay(150);
the original set shown well.
int menuitem = 1;
int frame = 1;
int page = 1;
what I modified shown some thing no good.
int menuitem = 3;
int frame = 2;
int page = 1;
changed back:
int menuitem = 1;
int frame = 1;
int page = 1;
still shown no good same as second. why?
I've changed the encoder input pin doesn't work, why?
encoder = new ClickEncoder(8, 9, 10);
