Does the while command work?
unsigned long oldTime = 0;
const long interval = 100;
unsigned long  sensorPin = A7 ;
unsigned long  sensor = A6 ;
unsigned long  sensorC =20;
int sensorMin = 1023;
int sensorMax = 0;
int sensorValue = 0;
byte calb=4;
byte out=5;
pinMode( sensor , INPUT);   //  modlar :
pinMode(sensorPin, INPUT);
pinMode  (out,OUTPUT);
pinMode  (calb,OUTPUT);
reads ();
  if((currentMillis - oldTime) > interval)
    oldTime = currentMillis;  }
       sensorC = analogRead(sensor);
     while (MinCAL>=MaxCAL)  { reads(); }
       digitalWrite  (out,1);
      sensorValue = analogRead(sensorPin);
  sensorValue = map(sensorValue, sensorMin, sensorMax, 0, 255);
  sensorValue = constrain(sensorValue, 0, 255);
  if ( sensorValue>=250 )
  {digitalWrite(calb, 1);}
  {digitalWrite(calb, 0);
 delay (10);}
void calibrate() {
  digitalWrite(  out, 0);
   if (sensorValue > sensorMax) {
   sensorMax = sensorValue;  }
  if (sensorValue < sensorMin) {
    sensorMin = sensorValue;
Hello there
I want to do
simultaneous reading of two analog inputs
A6 AND A7
I determined
The value of A6 analog voltage is 0-1023 this
If it goes above 20 when reading 0-20
I want the A7 to work and keep reading voltage.
   A7 won't work if analog goes below 0 -20
             delays with militia voltage
             instead of delay
you can suggest different codes
Can you help me
What gets you out of this loop?
I think you should use an unsigned long long instead (64 bits) just in case the PIN number is really high… :upside_down_face: :cold_face:
What’s that?
A few small errors to work out:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno"
In function 'void setup()':22:3: error: 'reads' was not declared in this scope
   reads();
 In function 'void loop()':35:10: error: 'MinCAL' was not declared in this scope
   while (MinCAL >= MaxCAL)
35:20: error: 'MaxCAL' was not declared in this scope
37:5: error: 'reads' was not declared in this scope
     reads();
At global scope:57:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
JML===
It was wrong
void reads()
johnwaseer
atmega328 programming with arduino uno
I think my code doesn't work while it doesn't exit the endless loop. I guess. Could you open the code you wrote?
Your code does not even compile…
void calibrate()
i make a lot of mistakes
it
void reads ();
Why don’t you post the real code, the one that you uploaded?
const long interval = 1000;
int sensorMax = 0;
unsigned int MinCAL = 10;
unsigned int MaxCAL = 1022;
byte calb=4;
byte out=5;
reads ();
 { if ( sensorValue>=250 )
 delay (10);}
void reads() {
okey
I compiled it but this example goes into an infinite loop as soon as it opens
So same question as in#2: what will make MinCal < MaxCAL ?
johnwas
Can you simplify the code you wrote for us?
while (MinCAL >= MaxCAL) post processing or jumping with goto
do while (MinCAL >= MaxCAL)
if (MinCAL >= MaxCAL) post processing
for (MinCAL >= MaxCAL) post processing
Why is it not possible to activate A7 with commands like
Which start is appropriate?
thanks
A "while" does the associated test BEFORE doing the loop. A "for" does the associated test AFTER the loop has been executed.
Paul
The point is whatever condition is in the test of a while needs to become false at some point if you don’t want to be in an infinite loop
Nope.
Must be remembering another programming language. They get conflated after a few years!
Paul
I think @Paul_KD7HB meant
do {
// code;
} while();
teacher when available
I want you to share a recommendation code
you are too busy on the site
you help everyone
I follow your posts
thank you
whether you write or not
Of course, I must also thank the site founder owners.
erewerw
The for loop is just a while loop in a posh frock.
