does this if/else make sense?
I am currently having issues entering the else state of this piece of code, and have no idea why this is the case.
This is the if/else statement.
      if(global_state == false)
        //do nothing
        digitalWrite(en_pin,HIGH);
        delay(1);
        unsigned int steps_to_speed;  // Steps required to achieve the the speed desired
        unsigned int acceleration_step_limit; // If desired speed is not achieved, will this variable contain step_limit to when to stop accelerating.
        if (motor_steps < 0)
          profile.dir = CCW;
          motor_steps = -motor_steps;
          digitalWrite(dir_pin,LOW);
          profile.dir = CW;
          digitalWrite(dir_pin,HIGH);
        delay(1);
      // If moving only 1 step.
        if (motor_steps == 1)
        // Move one step
          profile.accel_count = -1;
        // in DECEL state.
          profile.run_state = DECEL;
        // Just a short delay so main() can act on 'running'.
          profile.first_step_delay = 1000;
          OCR1A = 10;
        // Run Timer/Counter 1 with prescaler = 8.
          TCCR1B |= ((0 << CS12) | (1 << CS11) | (0 << CS10));
        else if (motor_steps != 0)
        // Set max speed limit, by calc min_delay to use in timer.
        // min_delay = (alpha / tt)/ w
          profile.min_time_delay = A_T_x100 / motor_speed;
        // Set accelration by calc the first (c0) step delay .
        // first_step_delay = 1/tt * sqrt(2*alpha/accel)
        // first_step_delay = ( tfreq*0.676/100 )*100 * sqrt( (2*alpha*10000000000) / (accel*100) )/10000
          profile.first_step_delay = (T1_FREQ_148 * sqrt(A_SQ / motor_accel)) / 100;
        // Find out after how many steps does the speed hit the max speed limit.
        // steps_to_speed = speed^2 / (2*alpha*accel)
          steps_to_speed = (long)motor_speed * motor_speed / (long)(((long)A_x20000 * motor_accel) / 100);
        // If we hit max speed limit before 0,5 step it will round to 0.
        // But in practice we need to move atleast 1 step to get any speed at all.
          if (steps_to_speed == 0)
            steps_to_speed = 1;
          // Find out after how many steps we must start deceleration.
          // n1 = (n1+n2)decel / (accel + decel)
          acceleration_step_limit = ((long)motor_steps * motor_decel) / (motor_accel + motor_decel);
          // We must accelrate at least 1 step before we can start deceleration.
          if (acceleration_step_limit == 0)
            acceleration_step_limit = 1;
          // Use the limit we hit first to calc decel.
          if (acceleration_step_limit <= steps_to_speed)
            //profile.decel_length = steps_to_speed - motor_steps;
            profile.decel_length = -(motor_steps-acceleration_step_limit); //---
            //profile.decel_length = -((long)steps_to_speed * acceleration_step_limit) / motor_decel;acceleration_step_limit
            profile.decel_length = -((long)steps_to_speed * motor_accel) / motor_decel; //--
          // We must decelrate at least 1 step to stop.
          if (profile.decel_length == 0)
            profile.decel_length = -1;
          // Find step to start decleration.
          //int steps_in_run = motor_steps - steps_to_speed-profile.decel_length;
          profile.decel_start = motor_steps + profile.decel_length;
        //profile.decel_start = motor_steps - steps_to_speed-steps_in_run;
        // If the maximum speed is so low that we dont need to go via accelration state.
          if (profile.first_step_delay <= profile.min_time_delay)
            profile.first_step_delay = profile.min_time_delay;
            profile.run_state = RUN;
            profile.run_state = ACCEL;
        // Reset counter.
          profile.accel_count = 0;
          OCR1A = 10;
        // Set Timer/Counter to divide clock by 8
          while(1)
            cli();
            status_step_count.data = profile.moved_steps;
            sei();
            chatter.publish( &status_step_count);
            nh.spinOnce();
            delay(1);
The code should enter the else state when global_state becomes true, but even thoug it becomes true will the code never enter the else statement…
Could someone clarify why this is the case? and what might be going wrong here?
Have you added some serial.print to check if it really is false.
Why not just have
if(global_state == true)
        //do something
Tom.... :slight_smile:
You gave us plenty of code but none that proves global_state becomes ever true... computer science theory would tend to say that if / else is pretty deterministic and works pretty well and thus if you don't go to else then I think means that the condition is never false and thus global_state is always false.
Please don't double post
I resolved the error..
215_215:
Good to know. Make sure you don't tell us what it was. Wouldn't want to inadvertently help somebody else with a similar problem...
evanmars:
My guess: global_state wasn't actually global.
In addition to not telling us what the problem was, I see that the OP has also not added "[solved]" to the title.
evanmars:
Hey I thought it was my turn to be sarcastic?
