Doesn't name type - Help
Hi all I am writing a program to use a temp and humidity receiver and then calculate the wet bulb temperature using an equation and then display it on a 1602 LCD. I have never worked with RF boards before and also need help in general
The first problem is my "wetbulb" equation is giving me the error 'wetbulb' does not name a type
could you pls also help with he code in whole
Please find the whole program attached
#include "RF24.h"
#include <LiquidCrystal.h>  //Includes the LCD library
RF24 myRadio (6, 7);
byte addresses[][6] = {"0"};
float remoteHumidity = 0.0;
float remoteTemperature = 0.0;
struct package
  float temperature ;
  float humidity ;
  float wetbulb = 0;
float previousRemoteHumidity = 0.1;
float previousRemoteTemperature = 0.1;
typedef struct package Package;
Package data;
float wetbulb = 0;
unsigned long lastMillis; // <----------<<<<
boolean flag;// <----------<<<<
byte temp[8] =             //icon for thermometer
  B00100,
  B01011,
  B01010,
  B01111,
  B01110,
  B11111,
  B11111,
  B01110
byte drop[8] =             //icon for Humidity Symbol
  B00100,
  B00100,
  B01110,
  B01110,
  B11111,
  B11111,
  B11111,
  B01110
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);  //Defines the LCD pins
byte bcdToDec(byte val) //Convert binary coded decimal to normal decimal numbers
  return ( (val / 16 * 10) + (val % 16) );
  lcd.createChar(1, temp);  // create a new character labeled 1
  lcd.createChar(2, drop);  // create a new character labeled 2
  lcd.begin(16, 2);  // set up the LCD's number of columns and rows
   lcd.begin(16, 2);
    lcd.setCursor(2, 0);
    lcd.print("MAKE IT SNOW");
    lcd.setCursor(4, 1);
    lcd.print(" .COM.AU");
    delay(80);
  //Display a welcome message on LCD when booting up
  startWirelessCommunication();
  printUI();
   checkForWirelessData();
   printRemoteTemperature();
   printRemoteHumidity();
wetbulb = (-5.806+0.672* t -0.006* t * t +(0.061+0.004* t +0.000099* t * t)* h +(-0.000033-0.000005* t -0.0000001*t * t )* h * h );  //This is the equation for wetbulb temperature
void startWirelessCommunication()
  myRadio.begin();
  myRadio.setChannel(115);
  myRadio.setPALevel(RF24_PA_MAX);
  myRadio.setDataRate( RF24_250KBPS ) ;
  myRadio.openReadingPipe(1, addresses[0]);
  myRadio.startListening();
  delay(100);
void checkForWirelessData()
    if ( myRadio.available())
    while (myRadio.available())
      myRadio.read( &data, sizeof(data) );
      previousRemoteTemperature = remoteTemperature;
      previousRemoteHumidity = remoteHumidity;
      remoteTemperature = Celcius2Fahrenheit(data.temperature);
      remoteHumidity = data.humidity;
    Serial.print("\nPackage:");
    Serial.print("\n");
    Serial.println(data.temperature);
    Serial.println(data.humidity);
void printUI()
   lcd.setCursor (0, 0);
    lcd.print("Wetbulb");  //Prints wetbulb label to the LCD
    lcd.print(" ");
    lcd.print(wetbulb);
    lcd.print((char)223);
    lcd.print("C");
void printRemoteHumidity()
  String humidity;
  if(remoteHumidity != previousRemoteHumidity)
    if(remoteHumidity == 0.0 && remoteTemperature == 0.0) //We just booted up
      humidity = "---";
    }else
          humidity = String(remoteHumidity,1);
  lcd.setCursor(0, 1);  //Position the LCD cursor (col 0, row 1)
  lcd.write(1);  //Print the new character labeled 1
  lcd.print(" ");
  lcd.print(Temperature);  //Print a message to the lcd.
  lcd.print((char)223);  //Prints the celicius Symbol
  lcd.print(" ");
  lcd.write(2);  //Print the new character labeled 2
  lcd.print(" ");
  lcd.print(Humidity);
  lcd.print("%");  //Prints the Pertcent symbol
void printRemoteTemperature()
  String temperature;
  if(remoteTemperature != previousRemoteTemperature)
      temperature = "---";
    }else if(remoteTemperature>=100)
      temperature = String(remoteTemperature,0);
    }else
        temperature = String(remoteTemperature,1);
  lcd.print(" ");
  lcd.print(" ");
  lcd.print(" ");
delay (1250);  //Sets the update interval for all functions
From where did you "borrow" this program?
That's the whole of your loop () function.
Did you mean to include the equation?
This line is not inside any function:
Thanks for the quick reply I have fixed the previous errors and a new one has arisen.
please have a look
Arduino: 1.6.12 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/TobyFarmer/Downloads/Wireless_Weather_Reciver/Wireless_Weather_Reciver.ino: In function 'void printRemoteTemperature()':
Wireless_Weather_Reciver:202: error: expected '}' at end of input
Multiple libraries were found for "LiquidCrystal.h"
 Used: /Users/TobyFarmer/Documents/Arduino/libraries/LiquidCrystal
 Not used: /Applications/Arduino.app/Contents/Java/libraries/LiquidCrystal
exit status 1
#include "RF24.h"
struct package
  float temperature ;
  float humidity ;
  float wetbulb = 0;
Package data;
float wetbulb = 0;
  B00100,
  B01011,
  B01010,
  B01111,
  B01110,
  B11111,
  B11111,
  B01110
  B00100,
  B00100,
  B01110,
  B01110,
  B11111,
  B11111,
  B11111,
  B01110
   lcd.begin(16, 2);
    delay(80);
  printUI();
    wetbulb = (-5.806+0.672* remoteTemperature -0.006* remoteTemperature * remoteTemperature +(0.061+0.004* remoteTemperature +0.000099* remoteTemperature * remoteTemperature)* remoteHumidity +(-0.000033-0.000005* remoteTemperature -0.0000001*remoteTemperature * remoteTemperature )* remoteHumidity * remoteHumidity );  //This is the equation for wetbulb temperature
  myRadio.begin();
  delay(100);
    Serial.print("\n");
void printUI()
    lcd.print(" ");
    lcd.print(wetbulb);
    lcd.print("C");
  String humidity;
      humidity = "---";
    }else
  lcd.print(" ");
  lcd.print(remoteTemperature);  //Print a message to the lcd.
  lcd.print(" ");
  lcd.print(" ");
  lcd.print(remoteHumidity);
  String temperature;
    }else
        String humidity;
      humidity = "---";
    }else
  lcd.print(" ");
  lcd.print(" ");
  lcd.print(" ");
all fixed I had two less "} and {"
thanks for the help all
