Hi. I have an arduino mega 2560. I have programmed it to do various functions (3 sensors and 2 relays) and everything is workings fine (temps, distance readings, relay management, etc).
But... when there is a lost in the connection, for example when there is a power failure at home... the arduino doesn't reconnect, not to wifi (not to mqtt server). BUT IT DOESN'T RECONNECT EVEN IF I UNPLUG AND RE-PLUG IT IN!....
Let me explain fisrt that it connects to wifi with an ESP01 board hanging. And that it is powered by an USB cable connected to a 5V wall socket.
But the really strange behaivour to me is that if I unplug wait and reconnect to the 5V power, it doesn't come back... BUT! If I connect it to a computer usb, and then open arduino IDE, and then open a terminal... THEN!!!, and only THEN!!!... is reconnecting correctly again. Once is reconnected, I can close the terminal, unplug from the computer walk away (arduino unpowered), and plug it in again to the wall socket, and starts perfectly, until next hang in which I loose contact and need to reconnect it to a computer and open TERMINAL, and only then, it resets some way that starts working on again. Does that make sense?.
How could the serial terminal when opened, be doing a proper 'reset', that a powerOFF/powerON is not making?.
Let me tell you that I haven't studied programming, just doing it as a hobby, so my code could be very very ugly (and wrong). I have done it reading here and there to achieve my goals with wifi and sensors, etc, and I have to say that... when it is connected to wifi and mqtt, everyhing is working smooth...
Here is the code. I thought first about reducing the extra lines without interest, but putting it complete, could be a better way of seeing if something can cause this behaiviour.
//****** LIBRERIAS DEL WIFI ********
#include <WiFiEspAT.h>
//****** LIBRERIAS DEL MQTT ********
#include <PubSubClient.h>
//****** LIBRERIAS DEL DHT22 ********
// DHT22: Include the libraries
#include <Adafruit_Sensor.h>
#include <DHT.h>
//****** LIBRERIAS DEL MAX31865 (pt100 temp tuberia) ********
#include <Adafruit_MAX31865.h>
//****** VARIABLES DEL DHT22 ********
//AQUI DEFINO LOS TOPICS PARA EL DHT22:
#define dht22TopicTemp "/arduino/dht22temperatura"
#define dht22TopicHume "/arduino/dht22humedad"
// DHT22: Set DHT pin
#define DHTPIN 2
// DHT22: Set DHT type
#define DHTTYPE DHT22 // DHT 22 (AM2302)
// DHT22: Initialize DHT sensor for normal 16mhz Arduino:
DHT dht = DHT(DHTPIN, DHTTYPE);
//****** VARIABLES PT100 (MAX31865) (temp tuberia) *******
Adafruit_MAX31865 thermo = Adafruit_MAX31865(10, 11, 12, 13);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF 430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL 100.0
// VARIABLES DE MILLIS PARA PAUSAS ENTRE CHEQUEOS DEL PT100 (temp tuberia):
unsigned long startMillisPT100; //some global variables available anywhere in the program
unsigned long currentMillisPT100;
//Y CREO OTRA VARIABLE ESPECIFICA PARA EL INTERVALO DE LECTURAS DEL SENSOR PT100 TEMPERATURA DE TUBERIA (max31865):
const unsigned long pausaPT100 = 45000; //45 secons pause between temp checks
// DEFINE TOPIC TO SAVE PT100 TEMP
#define pt100TopicTemp "/arduino/pt100temperatura"
//****** VARIABLES JSN-SR04T (ultrasonic distance waterproof) ********
//DEFINO LOS pines digitales trigger y echo en la mega2560:
#define trigPin 3
#define echoPin 4
//VARIABLES duration (tiempo entre trigger y echo) y distance (guarda la distancia calculada):
long duracion;
int distancia;
// VARIABLES DE MILLIS PARA PAUSAS ENTRE CHEQUEO DE SENSOR ULTRASONIDOS (distancia):
unsigned long startMillisUltrasonidos; //some global variables available anywhere in the program
unsigned long currentMillisUltrasonidos;
//CREO UNA VARIABLES ESPECIFICA PARA LA PAUSA ENTRE LECTURAS DEL SENSOR ULTRASONICO DE DISTANCIA WATERPROOF:
const unsigned long pausaUltrasonica = 30000; //30 segundos para la pausa entre chequeos de distancia
//DEFINE MQTT TOPIC TO SAVE ULTRASONIC DISTANCE:
#define ultrasonicoTopic "/arduino/ultrasonicodistancia"
//****** VARIABLES DEL WIFI ********
const char* ssid = "my_ssid";
const char* password = "my_password";
int status = WL_IDLE_STATUS; // the Wifi radio's status
//****** VARIABLES DEL MQTT DE LOS RELES ********
// Set led variables to Arduino digital pins
const int switchPin22 = 22;
const int switchPin23 = 23;
const int switchPin24 = 24;
const int switchPin25 = 25;
const int switchPin26 = 26;
const int switchPin27 = 27;
const int switchPin28 = 28;
const int switchPin29 = 29;
const int switchPin30 = 30;
const int switchPin31 = 31;
const int switchPin32 = 32;
const int switchPin33 = 33;
const int switchPin34 = 34;
const int switchPin35 = 35;
const int switchPin36 = 36;
const int switchPin37 = 37;
const int switchPin38 = 38;
//const int switchPin39 = 39; //SIN USO POR AHORA (CABLE MARRON), RELE OCTAVO DE LA PLACA RELE8
const int switchPin40 = 40;
const int switchPin41 = 41;
const int switchPin42 = 42;
const int switchPin43 = 43;
const int switchPin44 = 44;
const int switchPin45 = 45;
//EJ: These are the MQTT Topic that will be used to manage the state of Relays
char const* switchTopic22 = "/arduino/switch22";
char const* switchTopic23 = "/arduino/switch23";
char const* switchTopic24 = "/arduino/switch24";
char const* switchTopic25 = "/arduino/switch25";
char const* switchTopic26 = "/arduino/switch26";
char const* switchTopic27 = "/arduino/switch27";
char const* switchTopic28 = "/arduino/switch28";
char const* switchTopic29 = "/arduino/switch29";
char const* switchTopic30 = "/arduino/switch30";
char const* switchTopic31 = "/arduino/switch31";
char const* switchTopic32 = "/arduino/switch32";
char const* switchTopic33 = "/arduino/switch33";
char const* switchTopic34 = "/arduino/switch34";
char const* switchTopic35 = "/arduino/switch35";
char const* switchTopic36 = "/arduino/switch36";
char const* switchTopic37 = "/arduino/switch37";
char const* switchTopic38 = "/arduino/switch38";
//char const* switchTopic39 = "/arduino/switch39"; // //SIN USO POR AHORA (CABLE MARRON), RELE OCTAVO DE LA PLACA RELE8
char const* switchTopic40 = "/arduino/switch40";
char const* switchTopic41 = "/arduino/switch41";
char const* switchTopic42 = "/arduino/switch42";
char const* switchTopic43 = "/arduino/switch43";
char const* switchTopic44 = "/arduino/switch44";
char const* switchTopic45 = "/arduino/switch45";
//(50-53 SON DE LA ETHERNET-SHIELD, NO USAR)
//****** MORE WIFI VARIABLES
IPAddress ip(192, 168, 1, 159); // arduino IP in lan
IPAddress gateway(192, 168, 1, 2);
//****** MAS VARIABLES DEL MQTT ********
// IP Address of your MQTT broker - change to adapt to your network
byte mqtt_server[] = { 192, 168, 1, 193 }; //direccion de Hassio
// Handle and convert incoming MQTT messages ----------------------------------------
void callback(char* topic, byte* payload, unsigned int length);
// initialize the library instance:
WiFiClient clienteWifi;
PubSubClient mqttClient(mqtt_server, 1883, callback, clienteWifi);
//****** SETUP PINES ********
//initialize the switch as an output and set to HIGH (off)
//nota: de lo leido aqui: https://forum.arduino.cc/t/relay-module-is-active-low-how-to-reverse-that/264868/45
//poner primero el high y luego declarar el output para evitar jolgorio al bootear:
digitalWrite(switchPin22, HIGH);
pinMode(switchPin22, OUTPUT); // Relay 15
digitalWrite(switchPin23, HIGH);
pinMode(switchPin23, OUTPUT); // Relay 16
digitalWrite(switchPin24, HIGH);
pinMode(switchPin24, OUTPUT); // Relay 13
digitalWrite(switchPin25, HIGH);
pinMode(switchPin25, OUTPUT); // Relay 14
digitalWrite(switchPin26, HIGH);
pinMode(switchPin26, OUTPUT); // Relay 11
digitalWrite(switchPin27, HIGH);
pinMode(switchPin27, OUTPUT); // Relay 12
digitalWrite(switchPin28, HIGH);
pinMode(switchPin28, OUTPUT); // Relay 9
digitalWrite(switchPin29, HIGH);
pinMode(switchPin29, OUTPUT); // Relay 10
digitalWrite(switchPin30, HIGH);
pinMode(switchPin30, OUTPUT); // Relay 7
digitalWrite(switchPin31, HIGH);
pinMode(switchPin31, OUTPUT); // Relay 8
digitalWrite(switchPin32, HIGH);
pinMode(switchPin32, OUTPUT); // Relay 5
digitalWrite(switchPin33, HIGH);
pinMode(switchPin33, OUTPUT); // Relay 6
digitalWrite(switchPin34, HIGH);
pinMode(switchPin34, OUTPUT); // Relay 3
digitalWrite(switchPin35, HIGH);
pinMode(switchPin35, OUTPUT); // Relay 4
digitalWrite(switchPin36, HIGH);
pinMode(switchPin36, OUTPUT); // Relay 1
digitalWrite(switchPin37, HIGH);
pinMode(switchPin37, OUTPUT); // Relay 2
digitalWrite(switchPin38, HIGH);
pinMode(switchPin38, OUTPUT); // Relay-B 1
digitalWrite(switchPin40, HIGH);
pinMode(switchPin40, OUTPUT); // Relay-B 2
digitalWrite(switchPin41, HIGH);
pinMode(switchPin41, OUTPUT); // Relay-B 7
digitalWrite(switchPin42, HIGH);
pinMode(switchPin42, OUTPUT); // Relay-B 3
digitalWrite(switchPin43, HIGH);
pinMode(switchPin43, OUTPUT); // Relay-B 6
digitalWrite(switchPin44, HIGH);
pinMode(switchPin44, OUTPUT); // Relay-B 4
digitalWrite(switchPin45, HIGH);
pinMode(switchPin45, OUTPUT); // Relay-B 5
//wait a bit before starting the main loop
//****** SETUP DHT22 ********
// Setup sensor TEMP_y_HUMEDAD DHT22:
dht.begin();
//****** SETUP PT100 MAX31865 (temp tuberia) ********
thermo.begin(MAX31865_3WIRE); // set to 2WIRE or 4WIRE as necessary
//****** SETUP ULTRASONIC WATERPROOF ********
// set trigPin as OUTPUT and echopin as INPUT:
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
//****** NETWORK SETUP ********
// start serial port:
while (!Serial); // wait for serial port to connect. Needed for native USB port only
// CONFIGURACION WIFI:
Serial1.begin(115200);
WiFi.init(Serial1);
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// disconnect persistent connection (not persistent)
WiFi.disconnect();
// to disable default automatic start of persistent AP at startup
WiFi.endAP();
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// use following lines if you want to connect with bssid
// const byte bssid[] = {0x8A, 0x2F, 0xC3, 0xE9, 0x25, 0xC0};
// int status = WiFi.begin(ssid, password, bssid);
int status = WiFi.begin(ssid, password);
if (status == WL_CONNECTED) {
Serial.println("Connected to WiFi network.");
printWifiStatus();
WiFi.disconnect(); // remove the WiFi connection
Serial.println("Connection to WiFi network failed.");
//****** SETUP MQTT ********
if (mqttClient.connect("mega2560", "usuario_mqtt", "my_mqtt_password")) { //EJ: Update accordingly with your MQTT account
mqttClient.publish("arduino", "hello world from mega2560");
Serial.println("MQTT conectado");
mqttClient.subscribe(switchTopic22);
mqttClient.subscribe(switchTopic23);
mqttClient.subscribe(switchTopic24);
mqttClient.subscribe(switchTopic25);
mqttClient.subscribe(switchTopic26);
mqttClient.subscribe(switchTopic27);
mqttClient.subscribe(switchTopic28);
mqttClient.subscribe(switchTopic29);
mqttClient.subscribe(switchTopic30);
mqttClient.subscribe(switchTopic31);
mqttClient.subscribe(switchTopic32);
mqttClient.subscribe(switchTopic33);
mqttClient.subscribe(switchTopic34);
mqttClient.subscribe(switchTopic35);
mqttClient.subscribe(switchTopic36);
mqttClient.subscribe(switchTopic37);
mqttClient.subscribe(switchTopic38);
// mqttClient.subscribe(switchTopic39); //SIN USO POR AHORA
mqttClient.subscribe(switchTopic40);
mqttClient.subscribe(switchTopic41);
mqttClient.subscribe(switchTopic42);
mqttClient.subscribe(switchTopic43);
mqttClient.subscribe(switchTopic44);
mqttClient.subscribe(switchTopic45);
// Me apunto a los topics de dht22:
mqttClient.subscribe(dht22TopicTemp);
mqttClient.subscribe(dht22TopicHume);
// Me apunto al topic del sensor ultrasonico:
mqttClient.subscribe(ultrasonicoTopic);
// Me apunto al topic de pt100 temp tuberia:
mqttClient.subscribe(pt100TopicTemp);
//****** SETUP GLOBAL MILLIs ********
//Graba en variables el momento del arranque para comenzar a chequear periodos entre lecturas para dispositivos:
startMillisUltrasonidos = millis(); //initial start time
startMillisPT100 = millis(); //initial start time
} // FINAL DEL VOID SETUP
//dht22 SENSOR. CHECKS IF TEMP OR HUMIDITY CHANGED MORE THAN 0.1 AND REPUBLISH:
bool checkBound(float newValue, float prevValue, float maxDiff) {
return !isnan(newValue) &&
(newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
long lastMsg = 0;
float temp = 0.0;
float hum = 0.0;
float diff = 0.1;
//****** LOOP FUNCTION ********
//****** CHEQUEA IF MQTT IS STILL ALIVE ********
if (!mqttClient.connected()) {
reconnectMqtt();
//maintain MQTT connection
mqttClient.loop();
//****** LOOP DHT22 ********
long now = millis();
if (now - lastMsg > 5000) {
lastMsg = now;
float newTemp = dht.readTemperature();
float newHum = dht.readHumidity();
if (checkBound(newTemp, temp, diff)) {
temp = newTemp;
Serial.print("DHT22 Temperatura: ");
Serial.println(String(temp).c_str());
mqttClient.publish(dht22TopicTemp, String(temp).c_str(), true);
if (checkBound(newHum, hum, diff)) {
hum = newHum;
Serial.print("DHT22 Humedad: ");
Serial.println(String(hum).c_str());
mqttClient.publish(dht22TopicHume, String(hum).c_str(), true);
} //final del loop dht22
//****** LOOP ULTRASONIC: CHECK IF IT IS TIME TO START tareaUltrasonica ************
currentMillisUltrasonidos = millis(); //get the current "time" (actually the number of milliseconds since the program started)
// ULTRASONIDOS (distancia) SI TRANSCURRE EL PERIODO DEFINIDO PARA ULTRASONIDOS, EJECUTA LA FUNCION tareaUltrasonica:
if (currentMillisUltrasonidos - startMillisUltrasonidos >= pausaUltrasonica) //chequea si el periodo pausaUltrasonica (30s) ya ha transcurrido...
tareaUltrasonica(); // Si se cumple el periodo, llama a la funcion de tareas del tareaUltrasonica definida mas abajo.
startMillisUltrasonidos = currentMillisUltrasonidos; //IMPORTANT to save the start time of the current state.
//****** LOOP PT100: COMPRUEBA SI ES HORA DE EJECUTAR tareaPT100 ********
currentMillisPT100 = millis(); //get the current "time" (actually the number of milliseconds since the program started)
// PT100: SI TRANSCURRE EL PERIODO DEFINIDO PARA temp tuberia pt100, EJECUTA LA FUNCION tareaPT100:
if (currentMillisPT100 - startMillisPT100 >= pausaPT100) //chequea si el periodo pausaPT100 (45s) ya ha transcurrido...
tareaPT100(); // Hago que tambien lea la temp de pt100 (tuberia)
startMillisPT100 = currentMillisPT100; //IMPORTANT to save the start time of the current state.
} //FINAL DEL LOOP
//****** FUNCION PRINT WIFI STATUS ********
void printWifiStatus() {
// print the SSID of the network you're attached to:
char ssid[33];
WiFi.SSID(ssid);
Serial.print("SSID: ");
// print the BSSID of the network you're attached to:
uint8_t bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
uint8_t mac[6];
WiFi.macAddress(mac);
Serial.print("MAC: ");
printMacAddress(mac);
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
//****** FUNCION PRINT MAC ADDRESS ********
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
//****** FUNCION CALLBACK ********
//print any message received for subscribed topic
void callback(char* topic, byte* payload, unsigned int length) {
//convert topic to string to make it easier to work with
String topicStr = topic;
//EJ: Note: the "topic" value gets overwritten everytime it receives confirmation (callback) message from MQTT
//Print out some debugging info
Serial.print("Topic: ");
Serial.println(topicStr);
//PIN22
if (topicStr == "/arduino/switch22")
//turn the switch on if the payload is '1' and publish to the MQTT server a confirmation message
if (payload[0] == '1') {
digitalWrite(switchPin22, LOW);
mqttClient.publish("/arduino/switchConfirm22", "1");
if (digitalRead(22) == LOW) {
Serial.print("Valor pin 22: ON\n");
if (digitalRead(22) == HIGH) {
Serial.print("Valor pin 22: OFF\n");
//turn the switch off if the payload is '0' and publish to the MQTT server a confirmation message
else if (payload[0] == '0') {
mqttClient.publish("/arduino/switchConfirm22", "0");
//PIN23
// EJ: copy and paste this whole else-if block, should you need to control more switches
else if (topicStr == "/arduino/switch23")
digitalWrite(switchPin23, LOW);
mqttClient.publish("/arduino/switchConfirm23", "1");
if (digitalRead(23) == LOW) {
Serial.print("Valor pin 23: ON\n");
if (digitalRead(23) == HIGH) {
Serial.print("Valor pin 23: OFF\n");
mqttClient.publish("/arduino/switchConfirm23", "0");
//PIN24
else if (topicStr == "/arduino/switch24")
digitalWrite(switchPin24, LOW);
mqttClient.publish("/arduino/switchConfirm24", "1");
if (digitalRead(24) == LOW) {
Serial.print("Valor pin 24: ON\n");
if (digitalRead(24) == HIGH) {
Serial.print("Valor pin 24: OFF\n");
mqttClient.publish("/arduino/switchConfirm24", "0");
//PIN25
else if (topicStr == "/arduino/switch25")
digitalWrite(switchPin25, LOW);
mqttClient.publish("/arduino/switchConfirm25", "1");
if (digitalRead(25) == LOW) {
Serial.print("Valor pin 25: ON\n");
if (digitalRead(25) == HIGH) {
Serial.print("Valor pin 25: OFF\n");
mqttClient.publish("/arduino/switchConfirm25", "0");
//PIN26
else if (topicStr == "/arduino/switch26")
digitalWrite(switchPin26, LOW);
mqttClient.publish("/arduino/switchConfirm26", "1");
if (digitalRead(26) == LOW) {
Serial.print("Valor pin 26: ON\n");
if (digitalRead(26) == HIGH) {
Serial.print("Valor pin 26: OFF\n");
mqttClient.publish("/arduino/switchConfirm26", "0");
//PIN27
else if (topicStr == "/arduino/switch27")
digitalWrite(switchPin27, LOW);
mqttClient.publish("/arduino/switchConfirm27", "1");
if (digitalRead(27) == LOW) {
Serial.print("Valor pin 27: ON\n");
if (digitalRead(27) == HIGH) {
Serial.print("Valor pin 27: OFF\n");
mqttClient.publish("/arduino/switchConfirm27", "0");
//PIN28
else if (topicStr == "/arduino/switch28")
digitalWrite(switchPin28, LOW);
mqttClient.publish("/arduino/switchConfirm28", "1");
if (digitalRead(28) == LOW) {
Serial.print("Valor pin 28: ON\n");
if (digitalRead(28) == HIGH) {
Serial.print("Valor pin 28: OFF\n");
mqttClient.publish("/arduino/switchConfirm28", "0");
//PIN29
else if (topicStr == "/arduino/switch29")
digitalWrite(switchPin29, LOW);
mqttClient.publish("/arduino/switchConfirm29", "1");
if (digitalRead(29) == LOW) {
Serial.print("Valor pin 29: ON\n");
if (digitalRead(29) == HIGH) {
Serial.print("Valor pin 29: OFF\n");
mqttClient.publish("/arduino/switchConfirm29", "0");
//PIN30
else if (topicStr == "/arduino/switch30")
digitalWrite(switchPin30, LOW);
mqttClient.publish("/arduino/switchConfirm30", "1");
if (digitalRead(30) == LOW) {
Serial.print("Valor pin 30: ON\n");
if (digitalRead(30) == HIGH) {
Serial.print("Valor pin 30: OFF\n");
mqttClient.publish("/arduino/switchConfirm30", "0");
//PIN31
else if (topicStr == "/arduino/switch31")
digitalWrite(switchPin31, LOW);
mqttClient.publish("/arduino/switchConfirm31", "1");
if (digitalRead(31) == LOW) {
Serial.print("Valor pin 31: ON\n");
if (digitalRead(31) == HIGH) {
Serial.print("Valor pin 31: OFF\n");
mqttClient.publish("/arduino/switchConfirm31", "0");
//PIN32
else if (topicStr == "/arduino/switch32")
digitalWrite(switchPin32, LOW);
mqttClient.publish("/arduino/switchConfirm32", "1");
if (digitalRead(32) == LOW) {
Serial.print("Valor pin 32: ON\n");
if (digitalRead(32) == HIGH) {
Serial.print("Valor pin 32: OFF\n");
mqttClient.publish("/arduino/switchConfirm32", "0");
//PIN33
else if (topicStr == "/arduino/switch33")
digitalWrite(switchPin33, LOW);
mqttClient.publish("/arduino/switchConfirm33", "1");
if (digitalRead(33) == LOW) {
Serial.print("Valor pin 33: ON\n");
if (digitalRead(33) == HIGH) {
Serial.print("Valor pin 33: OFF\n");
mqttClient.publish("/arduino/switchConfirm33", "0");
//PIN34
else if (topicStr == "/arduino/switch34")
digitalWrite(switchPin34, LOW);
mqttClient.publish("/arduino/switchConfirm34", "1");
if (digitalRead(34) == LOW) {
Serial.print("Valor pin 34: ON\n");
if (digitalRead(34) == HIGH) {
Serial.print("Valor pin 34: OFF\n");
mqttClient.publish("/arduino/switchConfirm34", "0");
//PIN35
else if (topicStr == "/arduino/switch35")
digitalWrite(switchPin35, LOW);
mqttClient.publish("/arduino/switchConfirm35", "1");
if (digitalRead(35) == LOW) {
Serial.print("Valor pin 35: ON\n");
if (digitalRead(35) == HIGH) {
Serial.print("Valor pin 35: OFF\n");
mqttClient.publish("/arduino/switchConfirm35", "0");
//PIN36
else if (topicStr == "/arduino/switch36")
digitalWrite(switchPin36, LOW);
mqttClient.publish("/arduino/switchConfirm36", "1");
if (digitalRead(36) == LOW) {
Serial.print("Valor pin 36: ON\n");
if (digitalRead(36) == HIGH) {
Serial.print("Valor pin 36: OFF\n");
mqttClient.publish("/arduino/switchConfirm36", "0");
//PIN37
else if (topicStr == "/arduino/switch37")
digitalWrite(switchPin37, LOW);
mqttClient.publish("/arduino/switchConfirm37", "1");
if (digitalRead(37) == LOW) {
Serial.print("Valor pin 37: ON\n");
if (digitalRead(37) == HIGH) {
Serial.print("Valor pin 37: OFF\n");
mqttClient.publish("/arduino/switchConfirm37", "0");
//PIN38
else if (topicStr == "/arduino/switch38")
digitalWrite(switchPin38, LOW);
mqttClient.publish("/arduino/switchConfirm38", "1");
if (digitalRead(38) == LOW) {
Serial.print("Valor pin 38: ON\n");
if (digitalRead(38) == HIGH) {
Serial.print("Valor pin 38: OFF\n");
mqttClient.publish("/arduino/switchConfirm38", "0");
//DESACTIVO PORQUE ES PIN Y RELE SIN USO POR AHORA (RELE8 DE RELE8, CABLE MARRON, YA CONECTADO)
////PIN39
// // EJ: copy and paste this whole else-if block, should you need to control more switches
// else if (topicStr == "/arduino/switch39")
// //turn the switch on if the payload is '1' and publish to the MQTT server a confirmation message
// if(payload[0] == '1'){
// digitalWrite(switchPin39, LOW);
// mqttClient.publish("/arduino/switchConfirm39", "1");
// if (digitalRead(39)==LOW) { Serial.print("Valor pin 39: ON\n"); }
// if (digitalRead(39)==HIGH) { Serial.print("Valor pin 39: OFF\n"); }
// //turn the switch off if the payload is '0' and publish to the MQTT server a confirmation message
// else if (payload[0] == '0'){
// digitalWrite(switchPin39, HIGH);
// mqttClient.publish("/arduino/switchConfirm39", "0");
//PIN40
else if (topicStr == "/arduino/switch40")
digitalWrite(switchPin40, LOW);
mqttClient.publish("/arduino/switchConfirm40", "1");
if (digitalRead(40) == LOW) {
Serial.print("Valor pin 40: ON\n");
if (digitalRead(40) == HIGH) {
Serial.print("Valor pin 40: OFF\n");
mqttClient.publish("/arduino/switchConfirm40", "0");
//PIN41
else if (topicStr == "/arduino/switch41")
digitalWrite(switchPin41, LOW);
mqttClient.publish("/arduino/switchConfirm41", "1");
if (digitalRead(41) == LOW) {
Serial.print("Valor pin 41: ON\n");
if (digitalRead(41) == HIGH) {
Serial.print("Valor pin 41: OFF\n");
mqttClient.publish("/arduino/switchConfirm41", "0");
//PIN42
else if (topicStr == "/arduino/switch42")
digitalWrite(switchPin42, LOW);
mqttClient.publish("/arduino/switchConfirm42", "1");
if (digitalRead(42) == LOW) {
Serial.print("Valor pin 42: ON\n");
if (digitalRead(42) == HIGH) {
Serial.print("Valor pin 42: OFF\n");
mqttClient.publish("/arduino/switchConfirm42", "0");
//PIN43
else if (topicStr == "/arduino/switch43")
digitalWrite(switchPin43, LOW);
mqttClient.publish("/arduino/switchConfirm43", "1");
if (digitalRead(43) == LOW) {
Serial.print("Valor pin 43: ON\n");
if (digitalRead(43) == HIGH) {
Serial.print("Valor pin 43: OFF\n");
mqttClient.publish("/arduino/switchConfirm43", "0");
//PIN44
else if (topicStr == "/arduino/switch44")
digitalWrite(switchPin44, LOW);
mqttClient.publish("/arduino/switchConfirm44", "1");
if (digitalRead(44) == LOW) {
Serial.print("Valor pin 44: ON\n");
if (digitalRead(44) == HIGH) {
Serial.print("Valor pin 44: OFF\n");
mqttClient.publish("/arduino/switchConfirm44", "0");
//PIN45
else if (topicStr == "/arduino/switch45")
digitalWrite(switchPin45, LOW);
mqttClient.publish("/arduino/switchConfirm45", "1");
if (digitalRead(45) == LOW) {
Serial.print("Valor pin 45: ON\n");
if (digitalRead(45) == HIGH) {
Serial.print("Valor pin 45: OFF\n");
mqttClient.publish("/arduino/switchConfirm45", "0");
} // FINAL DE FUNCION VOID CALLBACK
//****** FUNCION RECONNECTMQTT (check mqtt) ********
// FUNCIONES DE CHEQUEO Y RECONEXION DE MQTT SI SE PIERDE CONEXION CON MQTT SERVER:
// Reconecta si pierde conexion con el servidor MQTT (HA) -----------------------------------
void reconnectMqtt() {
// Loop until we're reconnected al servidor mqtt:
while (!mqttClient.connected()) {
Serial.print("Trying to connect to MQTT...");
// Attempt to connect
mqttClient.publish("arduino", "hello world - AGAIN mega2560");
Serial.println("\nMQTT RE-connected\n");
// Subscribe or resubscribe to a topic
// You can subscribe to more topics (to control more outputs)
// mqttClient.subscribe(switchTopic39); // SIN USO POR AHORA
//DHT22 que se reconecte tambien a la temperatura de DHT22:
//ULTRASONICO, que se reconecte tambien al topic de distancia:
//PT100 que se reconecte tambien a la temp tuberia del PT100 (max31865):
Serial.print("failed, rc=");
Serial.print(mqttClient.state());
// Muestra la razon del codigo de fallo de conexion al mqtt server:
if (mqttClient.state() == -4) {
Serial.print("\nMQTT_CONNECTION_TIMEOUT server did not respond within the keepalive time\n");
if (mqttClient.state() == -3) {
Serial.print("\nMQTT_CONNECTION_LOST network connection was broken\n");
if (mqttClient.state() == -2) {
Serial.print("\nMQTT_CONNECT_FAILED network connection failed\n");
if (mqttClient.state() == -1) {
Serial.print("\nMQTT_DISCONNECTED client is disconnected cleanly\n");
if (mqttClient.state() == 0) {
Serial.print("\nMQTT_CONNECTED client is connected\n");
if (mqttClient.state() == 1) {
Serial.print("\nMQTT_CONNECT_BAD_PROTOCOL server does not support the requested version of MQTT\n");
if (mqttClient.state() == 2) {
Serial.print("\nMQTT_CONNECT_BAD_CLIENT_ID server rejected the client identifier\n");
if (mqttClient.state() == 3) {
Serial.print("\nMQTT_CONNECT_UNAVAILABLE server was unable to accept the connection\n");
if (mqttClient.state() == 4) {
Serial.print("\nMQTT_CONNECT_BAD_CREDENTIALS username-password were rejected\n");
Serial.print("\nMQTT_CONNECT_UNAUTHORIZED client was not authorized to connect\n");
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
} //FINAL FUNCION RECONNECT MQTT
//****** FUNCION ULTRASONIC TASK for the LOOP: ********
void tareaUltrasonica() {
// LIMPIA EL TRIGGER PIN PONIENDOLO EN LOW:
digitalWrite(trigPin, LOW);
// Y METE UNA PAUSITA (DEL TUTO):
delayMicroseconds(5);
// PONE DURANTE 10 MICROSEGUNDOS EL PIN TRIGGER EN HIGH:
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// LEE EL PIN ECHO. pulseIn() DA LA DURACION EN MICROSEGUNDOS:
duracion = pulseIn(echoPin, HIGH);
// CALCULATE DISTANCE:
distancia = duracion * 0.034 / 2;
// PRINT DISTANCE:
Serial.print("Distancia: ");
Serial.print(distancia);
Serial.println(" cm");
// AND PUBLISH ON MQTT:
mqttClient.publish(ultrasonicoTopic, String(distancia).c_str(), true);
//METE OTRA MINIPAUSA:
delay(100);
} // FIN tareaUltrasonica
//****** FUNCION TASK PT100 (max31865) for the LOOP: ********
void tareaPT100() {
uint16_t rtd = thermo.readRTD();
Serial.print("PT100 RTD value: "); Serial.println(rtd);
float ratio = rtd;
ratio /= 32768;
Serial.print("PT100 Ratio = "); Serial.println(ratio, 8);
Serial.print("PT100 Resistencia = "); Serial.println(RREF * ratio, 8);
float pt100temp = thermo.temperature(RNOMINAL, RREF);
Serial.print("PT100 Temperatura = "); Serial.println(pt100temp);
// Y LA PUBLICA EN EL TOPIC DE MQTT:
mqttClient.publish(pt100TopicTemp, String(pt100temp).c_str(), true);
// Check and print any faults
uint8_t fault = thermo.readFault();
if (fault) {
Serial.print("PT100 Fault 0x"); Serial.println(fault, HEX);
if (fault & MAX31865_FAULT_HIGHTHRESH) {
Serial.println("PT100 RTD High Threshold");
if (fault & MAX31865_FAULT_LOWTHRESH) {
Serial.println("PT100 RTD Low Threshold");
if (fault & MAX31865_FAULT_REFINLOW) {
Serial.println("PT100 REFIN- > 0.85 x Bias");
if (fault & MAX31865_FAULT_REFINHIGH) {
Serial.println("PT100 REFIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_RTDINLOW) {
Serial.println("PT100 RTDIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_OVUV) {
Serial.println("PT100 Under/Over voltage");
thermo.clearFault();
} // FIN tareaMax31865
//fin
