Doesn't stay in sub menu
So hello everyone. I'm creating simple menu with few sub menus,on my lcd screen. But i have run into small problem, i can't stay in my sub menu. When i press select button, it goes into submenu section and after maybe 1-2 sec it goes back to main menu.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
int upButton = 10;
int downButton = 11;
int selectButton = 12;
int menu = 1;
  lcd.begin();
  lcd.backlight();
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(selectButton, INPUT_PULLUP);
  updateMenu();
  if (!digitalRead(downButton)){
    menu++;
    updateMenu();
    delay(100);
    while (!digitalRead(downButton));
  if (!digitalRead(upButton)){
    menu--;
    updateMenu();
    delay(100);
    while(!digitalRead(upButton));
  if (!digitalRead(selectButton)){
    executeAction();
    updateMenu();
    delay(100);
    while (!digitalRead(selectButton));
void updateMenu() {
  switch (menu) {
    case 0:
      menu = 1;
    case 1:
      lcd.clear();
      lcd.print(">MenuItem1");
      lcd.setCursor(0, 1);
      lcd.print(" MenuItem2");
    case 2:
      lcd.clear();
      lcd.print(" MenuItem1");
      lcd.print(">MenuItem2");
    case 3:
      lcd.clear();
      lcd.print(">MenuItem3");
      lcd.print(" MenuItem4");
    case 4:
      lcd.clear();
      lcd.print(" MenuItem3");
      lcd.print(">MenuItem4");
    case 5:
      menu = 4;
void executeAction() {
  switch (menu) {
    case 1:
      action1();
    case 2:
      action2();
    case 3:
      action3();
    case 4:
      action4();
void action1() {
  lcd.clear();
  lcd.print(">Executing #1");
  delay(1500);
void action2() {
  lcd.clear();
  lcd.print(">Executing #2");
  delay(1500);
void action3() {
  lcd.clear();
  lcd.print(">Executing #3");
  delay(1500);
void action4() {
  lcd.clear();
  lcd.print(">Executing #4");
  delay(1500);
Thanks in advanced
Hello,
your sketch do what you have coded :slight_smile:
You may better structure your sketch wrt IPO model.
Input: Buttons, including debouncing
Processing: FSM for LCD handling
Output: your desired functions
And avoid the usage of the delay() function. A homebrewed timer function will be the better way always.
Hello
I modified your sketch and I think that was what you had in mind to achieve your design goal.
Please review it and don't hesitate if you have more questions.
A microLogic analyzer to see what happens inside I have not deleted.
#include <Wire.h>
enum {Up, Down, Select};
const int UpButton {A0};
const int DownButton = {A1};
const int SelectButton = {A2};
int menu = 1;
struct BUTTON {
  byte pin;
  bool state;
  int click;
  unsigned long timeStamp;
  unsigned long duration;
} button[] {
  {UpButton, 1, 1, 0, 20},
  {DownButton, 1, 1, 0, 20},
  {SelectButton, 1, 1, 0, 20},
void debounce() {
  for (auto &make : button) {
    if (millis() - make.timeStamp >= make.duration) {
      make.timeStamp = millis();
      make.state = digitalRead(make.pin);
enum {Pressed, Released, Nothing};
int click (BUTTON &button) {
  if (button.click == button.state) return Nothing;
  button.click = button.state;
  return button.click;
  lcd.init(); // initialize the lcd
  lcd.backlight();
  lcd.setContrast(255);
  for (auto make : button) pinMode(make.pin, INPUT_PULLUP);
  updateMenu();
  Serial.println("und los geht´s");
  debounce();
  int buttonRead = click(button[Down]);
  if (buttonRead == Pressed) Serial.println("DownButton pressed");
  if (buttonRead == Pressed) {
    menu++;
    updateMenu();
  buttonRead = click(button[Up]);
  if (buttonRead == Pressed) Serial.println("UpButton pressed");
    menu--;
    updateMenu();
  buttonRead = click(button[Select]);
  if (buttonRead == Pressed) Serial.println("SelectButton pressed");
    static bool selectAction;
    if (!selectAction) executeAction();
    if (selectAction) updateMenu();
    selectAction = !selectAction;
void updateMenu() {
  switch (menu) {
    case 0:
      menu = 1;
    case 1:
      lcd.clear();
    case 2:
      lcd.clear();
    case 3:
      lcd.clear();
    case 4:
      lcd.clear();
    case 5:
      menu = 4;
  switch (menu) {
    case 1:
      action1();
    case 2:
      action2();
    case 3:
      action3();
    case 4:
      action4();
void action1() {
  lcd.clear();
void action2() {
  lcd.clear();
void action3() {
  lcd.clear();
void action4() {
  lcd.clear();
Ok, i have a lot of questions :smiley:
First, why are you using enum with buttons?
Second, why const int UpButton {A0}; is in {} brackets? I changed to 2,3,4 digital bin btw.
And last, button massive (button[] {
{SelectButton, 1, 1, 0, 20}) , why is used massive, in such i guess "simple task"?
Btw, amazing work, big thanks!
Hello
Here ny answers:
The enum´s are used give the name a number.
Up=0
Down=1
Select =2
This one way of many ways to inialize variables with values
And last, button massive (button {
The complete instruction is:
struct BUTTON {
  byte pin;
  bool state;
  int click;
} button[] {
I have make an object for the buttons containing all relevant information and data for an easy way to use within the sketch.
This topic was automatically closed after 120 days. New replies are no longer allowed.
