# Door Chime randomly going off...
**URL:** <https://forum.arduino.cc/t/door-chime-randomly-going-off/523992>\
**Category:** IDE 1.x\
**Created:** [May 3, 2018, 3:06pm UTC](https://forum.arduino.cc/t/door-chime-randomly-going-off/523992 "2018-05-03T15:06:23Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Heliman](https://avatars.discourse-cdn.com/v4/letter/h/f1d935/32.png) [@Heliman](https://forum.arduino.cc/u/Heliman)\
**Post date:** [May 3, 2018, 3:06pm UTC](https://forum.arduino.cc/t/door-chime-randomly-going-off/523992/1 "2018-05-03T15:06:23Z")
</div>
Hello,
I made a door chime using a reed switch and an arduino uno I believe. The door chime randomly goes off at times and I am trying to troubleshoot the problem. It is hooked up to a rather long cable run like prob around 30 to 45ft. Maybe I am getting electromagnetic interference? I will post my code below to see if anyone can spot a problem with it and maybe have a solution to fix it via code.
```cpp
Rameez Saiyid
Reed Switch and Arduino
4.9.15
const int switchPin = 5;
const int ledPin = 10;
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS    7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4    // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3      // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  pinMode(switchPin, INPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(switchPin, HIGH);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
    Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
    while (1);
  Serial.println(F("VS1053 found"));
  SD.begin(CARDCS);    // initialise the SD card
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
if(digitalRead(switchPin) == LOW){
digitalWrite(ledPin, LOW);
else{
digitalWrite(ledPin, HIGH);
  // Play one file, don't return until complete
  Serial.println(F("Playing track 001"));
  musicPlayer.playFullFile("track001.mp3");
delay (2000);
while (digitalRead(switchPin) == HIGH) ; // do nothing
```cpp
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <SPI.h>
#include <SD.h>
// define the pins used
//#define CLK 13      // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS    10    // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
    while (1);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play another file in the background, REQUIRES interrupts!
  Serial.println(F("Playing track 002"));
  musicPlayer.startPlayingFile("track002.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1);
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  delay(100);
**Post date:** [May 5, 2021, 4:18pm UTC](https://forum.arduino.cc/t/door-chime-randomly-going-off/523992/2 "2021-05-05T16:18:51Z")
</div>
