help me make an arduino uno based door lock which can store multiple rfid card in eeprom memory and a pin which can also be stored in the eeprom memory the pin and card should be changeable and should automatically stored in eeprom so that the uno can be restarted. for input we are using 4x4 keypad for display using i2c 16x2 display for rfic mcr522 sensor. Also the first time the code run it will ask to set a master pin which will than get stored in the eeprom than after storing it will change a variable in the eeprom which will help later letting the program know that a pin is set already and will not display the pin setting program again on startup to change the pin there will be options on the display to choose and after confirming the pin than only the pin can be changed.
I have Made Some Progress will share the code till now.
Be sure to format the code by clicking the < CODE > button and pasting your code where you see '''type or paste code here'''
#include <Keypad.h>
#include <Wire.h>
#include <EEPROM.h>
#include <MFRC522.h>
#include <SPI.h>
#define MASTER_PIN_ADDRESS 0 // EEPROM address to store master pin
#define CARD_COUNT_ADDRESS 1 // EEPROM address to store card count
#define MAX_CARDS 10
#define MAX_PIN_LENGTH 4
#define RST_PIN 11 // Reset pin
#define SS_PIN 10
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {A1, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27, 16, 2); // Set the LCD address to 0x27 for a 16 chars and 2 line display
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
char masterPin[MAX_PIN_LENGTH + 1]; // Variable to store master pin
bool masterPinSet = false; // Flag to check if master pin is set
byte cardCount = 0; // Number of cards stored
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
lcd.begin(); // Initialize the lcd
lcd.backlight();
// Check if master pin is set
masterPinSet = EEPROM.read(MASTER_PIN_ADDRESS);
if (masterPinSet==0) {
setMasterPin();
// Retrieve card count from EEPROM
cardCount = EEPROM.read(CARD_COUNT_ADDRESS);
void setMasterPin() {
lcd.clear();
lcd.print("Set Master PIN:");
char tempPin[MAX_PIN_LENGTH + 1];
int index = 0;
while (true) {
char key = keypad.getKey();
if (key != NO_KEY) {
if (key == '#') {
if (index > 0) {
tempPin[index] = '\0';
strcpy(masterPin, tempPin);
EEPROM.put(MASTER_PIN_ADDRESS, masterPin);
masterPinSet = true;
EEPROM.write(MASTER_PIN_ADDRESS, 1); // Set flag to indicate master pin is set
lcd.clear();
lcd.print("Master PIN Set");
return;
} else if (index < MAX_PIN_LENGTH && isDigit(key)) {
tempPin[index++] = key;
lcd.setCursor(index - 1, 1);
lcd.print('*');
bool addCardToMemory() {
if (cardCount >= MAX_CARDS) {
lcd.clear();
lcd.print("Max cards reached");
return false;
lcd.clear();
lcd.print("Present a card");
// Wait for card
if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
return false;
// Read UID
String cardUID = "";
for (byte i = 0; i < mfrc522.uid.size; i++) {
cardUID.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : ""));
cardUID.concat(String(mfrc522.uid.uidByte[i], HEX));
// Check if card already exists
for (int i = 0; i < cardCount; i++) {
String storedUID = "";
for (int j = 0; j < 4; j++) {
storedUID.concat(String(EEPROM.read(MASTER_PIN_ADDRESS + 1 + i * 4 + j), HEX));
if (cardUID == storedUID) {
lcd.clear();
lcd.print("Card already exists");
return false;
// Store card in EEPROM
for (int i = 0; i < 4; i++) {
EEPROM.write(MASTER_PIN_ADDRESS + 1 + cardCount * 4 + i, strtoul(cardUID.substring(i * 2, i * 2 + 2).c_str(), NULL, 16));
cardCount++;
EEPROM.write(CARD_COUNT_ADDRESS, cardCount);
lcd.clear();
lcd.print("Card added");
return true;
void removeCardFromMemory() {
lcd.clear();
lcd.print("Present card");
// Wait for card
return;
// Read UID
// Check if card exists and remove it
// Shift remaining cards to fill the gap
for (int k = i; k < cardCount - 1; k++) {
EEPROM.write(MASTER_PIN_ADDRESS + 1 + k * 4 + j, EEPROM.read(MASTER_PIN_ADDRESS + 1 + (k + 1) * 4 + j));
cardCount--;
lcd.clear();
lcd.print("Card removed");
return;
lcd.clear();
lcd.print("Card not found");
void handlePinInput(char key) {
static char enteredPin[MAX_PIN_LENGTH + 1];
static int index = 0;
if (key == '*') {
// Asterisk (*) entered, clear entered PIN
memset(enteredPin, 0, sizeof(enteredPin));
index = 0;
lcd.clear();
lcd.print("Enter PIN:");
return;
if (key == '#') {
// Pound (#) entered, verify PIN
if (index == MAX_PIN_LENGTH) {
enteredPin[index] = '\0';
if (strcmp(enteredPin, masterPin) == 0) {
unlockDoor(); // Correct PIN entered, unlock door
lcd.clear();
lcd.print("Invalid PIN");
lcd.clear();
lcd.print("Standby Mode");
lcd.clear();
lcd.clear();
return;
// Append digit to entered PIN
enteredPin[index++] = key;
lcd.print('*');
void masterMode() {
lcd.clear();
lcd.print("Master Mode");
lcd.setCursor(0, 1);
lcd.print("1: Change PIN");
lcd.setCursor(0, 2);
lcd.print("2: Add Card");
lcd.setCursor(0, 3);
lcd.print("3: Remove Card");
while (true) {
if (key == '1') {
changeMasterPin();
return;
} else if (key == '2') {
addCardToMemory();
return;
} else if (key == '3') {
removeCardFromMemory();
return;
void changeMasterPin() {
lcd.clear();
lcd.print("Enter new PIN:");
char newPin[MAX_PIN_LENGTH + 1];
int index = 0;
while (true) {
if (key == '#') {
newPin[index] = '\0';
strcpy(masterPin, newPin);
lcd.clear();
lcd.print("PIN changed");
lcd.clear();
return;
newPin[index++] = key;
lcd.print('*');
delay(100);
void unlockDoor() {
// Implement your door unlocking mechanism here.
// For example, you can activate a relay connected to the door lock.
void handleCardDetection() {
if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
// Check if card exists in memory
unlockDoor(); // Card matched, unlock door
return;
lcd.clear();
lcd.print("Unknown Card");
lcd.clear();
void standbyMode() {
lcd.clear();
while (true) {
if (key == '*') {
lcd.clear();
handlePinInput('*');
return;
delay(100);
if (masterPinSet==1) {
standbyMode();
if (key == '#') {
masterMode(); // Enter master mode
return;
if (key != NO_KEY && key != '*' && key != '#') {
handlePinInput(key);
handleCardDetection();
Ask ChatGPT if the code it gave to you works.
I do not see how this relates to "Interfacing w/ Software on the Computer". Hence your topic had been moved to a more suitable location on the forum.
Thank You
The code is created by me only I took some reference but gpt isn't following what I want so I did it myself my problem is it gets stuck on standby after setting up the pin I don't know why🥲
Your command of the English language really shows in the program comments only.
You even refer to yourself in the second person?
Where did you copy this? What does it say?
As I told earlier I tried using the code from chatgpt only however the code was not what I wanted so I changed alot in it. And the code is this after changing
I asked gpt to fix the problems many times but found no success in that infact I had to go through the code line by line to understand what was happening and how it was working and tried fixing it my self. The code is compiling perfectly but still I don't know wheather there is a mistake that I made in the standby mode or void loop which is causing it to get stuck on stand by mode after setting up the pin. On first boot. I'm asking for help please help. And sorry for the inconvenience I may have caused.
Here, I will help:
- Discard GPT code until you understand how programming works.
- Write a sketch for each device until you understand how to use each device and each sketch.
- Use your learned skills to create sketches integrating devices.
Why would you want someone else to write code? It won't be your code and you will never know how it works. Enjoy learning and applying your knowledge.
