Door lock with keypad.
Good day to all forum members.
I need a little help about a project i am about to start. The project is the "well known" Door lock with keypad.
Before i continue with my concerns i have to say (what i pretty much say in all the topics i start) that i am new to programming and i have very very little knowledge on it.
I have found a nice tutorial somewhere online about the project. Im posting the code below.
It uses the 4x4 keypad with 10k resistors on the col pins but without diodes. The keypad layout is the one in the very first diagram shown here https://gammon.com.au/forum/?id=14175
I dont have all the parts needed yet to build it and field test it also i have done google search but so far i failed to figure out what will happen if someone starts pressing all the buttons at the same time or even worse if someone keeps pressing and releasing all buttons many times ? from what i understand by reading the code the arduino will do nothing unless it gets * or #
but still if a */# is pressed and then all together ?
/* This code works with 4x4 Keypad Matrix, LCD ic, IRF510N transistor and a push button
 * It's a lock where the transistor drives a solenoid lock you can open either with correct code
 * or by the push button from inside
 * The code can be changed directly by the keypad and doesn't require uploading code again
 * Code is stored in EEPROM
 * Refer to www.surtrtech.com for more details
#include <Keypad.h>
#include <EEPROM.h>
#define Solenoid 11             //Actually the Gate of the transistor that controls the solenoid
#define O_Button 10             //Push Button
#define I2C_ADDR 0x27           //I2C adress, you should use the code to scan the adress first (0x27) here
#define BACKLIGHT_PIN 3         // Declaring LCD Pins
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
const byte numRows= 4;          //number of rows on the keypad
const byte numCols= 4;          //number of columns on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
char keypressed;                 //Where the keys are stored it changes very often
char code[]= {'6','6','0','1'};  //The default code, you can change it or make it a 'n' digits one
char code_buff1[sizeof(code)];  //Where the new key is stored
char code_buff2[sizeof(code)];  //Where the new key is stored again so it's compared to the previous one
short a=0,i=0,s=0,j=0;          //Variables used later
byte rowPins[numRows] = {9,8,7,6}; //Rows 0 to 3 //if you modify your pins you should modify this too
byte colPins[numCols]= {5,4,3,2}; //Columns 0 to 3
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
          lcd.begin (16,2);
          lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
          lcd.setBacklight(HIGH); //Lighting backlight
          lcd.home ();
          lcd.print("Standby");      //What's written on the LCD you can change
          pinMode(Solenoid,OUTPUT);
          pinMode(O_Button,INPUT);
//          for(i=0 ; i<sizeof(code);i++){        //When you upload the code the first time keep it commented
//            EEPROM.get(i, code[i]);             //Upload the code and change it to store it in the EEPROM
//             }                                  //Then uncomment this for loop and reupload the code (It's done only once)
here is the rest of the code:
  keypressed = myKeypad.getKey();               //Constantly waiting for a key to be pressed
    if(keypressed == '*'){                      // * to open the lock
            lcd.clear();
            lcd.setCursor(0,0);
            lcd.print("Enter code");            //Message to show
            GetCode();                          //Getting code function
                  if(a==sizeof(code))           //The GetCode function assign a value to a (it's correct when it has the size of the code array)
                  OpenDoor();                   //Open lock function if code is correct
                  else{
                  lcd.clear();
                  lcd.print("Wrong");          //Message to print when the code is wrong
            delay(2000);
            lcd.clear();
            lcd.print("Standby");             //Return to standby mode it's the message do display when waiting
     if(keypressed == '#'){                  //To change the code it calls the changecode function
      ChangeCode();
      lcd.clear();
      lcd.print("Standby");                 //When done it returns to standby mode
     if(digitalRead(O_Button)==HIGH){      //Opening by the push button
       digitalWrite(Solenoid,HIGH);
       delay(3000);                        //Opens for 3s you can change
       digitalWrite(Solenoid,LOW);
void GetCode(){                  //Getting code sequence
       i=0;                      //All variables set to 0
       a=0;
       j=0;
     while(keypressed != 'A'){                                     //The user press A to confirm the code otherwise he can keep typing
             if(keypressed != NO_KEY && keypressed != 'A' ){       //If the char typed isn't A and neither "nothing"
              lcd.setCursor(j,1);                                  //This to write "*" on the LCD whenever a key is pressed it's position is controlled by j
              lcd.print("*");
              j++;
            if(keypressed == code[i]&& i<sizeof(code)){            //if the char typed is correct a and i increments to verify the next caracter
                 a++;                                              //Now I think maybe I should have use only a or i ... too lazy to test it -_-'
                 i++;
                a--;                                               //if the character typed is wrong a decrements and cannot equal the size of code []
    keypressed = NO_KEY;
void ChangeCode(){                      //Change code sequence
      lcd.clear();
      lcd.print("Changing code");
      lcd.clear();
      lcd.print("Enter old code");
      GetCode();                      //verify the old code first so you can change it
            if(a==sizeof(code)){      //again verifying the a value
            lcd.clear();
            GetNewCode1();            //Get the new code
            GetNewCode2();            //Get the new code again to confirm it
            s=0;
              for(i=0 ; i<sizeof(code) ; i++){     //Compare codes in array 1 and array 2 from two previous functions
              if(code_buff1[i]==code_buff2[i])
              s++;                                //again this how we verifiy, increment s whenever codes are matching
                  if(s==sizeof(code)){            //Correct is always the size of the array
                  code[i]=code_buff2[i];         //the code array now receives the new code
                  EEPROM.put(i, code[i]);        //And stores it in the EEPROM
                  lcd.clear();
                  lcd.print("Code Changed");
                  delay(2000);
                  else{                         //In case the new codes aren't matching
                  lcd.clear();
                  lcd.print("Codes are not");
                  lcd.setCursor(0,1);
                  lcd.print("matching !!");
                  delay(2000);
          else{                     //In case the old code is wrong you can't change it
          lcd.clear();
          lcd.print("Wrong");
          delay(2000);
void GetNewCode1(){
  i=0;
  j=0;
  lcd.clear();
  lcd.print("Enter new code");   //tell the user to enter the new code and press A
  lcd.setCursor(0,1);
  lcd.print("and press A");
  delay(2000);
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print("and press A");     //Press A keep showing while the top row print ***
         while(keypressed != 'A'){            //A to confirm and quits the loop
                lcd.setCursor(j,0);
                lcd.print("*");               //On the new code you can show * as I did or change it to keypressed to show the keys
                code_buff1[i]=keypressed;     //Store caracters in the array
                i++;
                j++;
void GetNewCode2(){                         //This is exactly like the GetNewCode1 function but this time the code is stored in another array
  i=0;
  j=0;
  lcd.clear();
  lcd.print("Confirm code");
  lcd.setCursor(0,1);
  delay(3000);
  lcd.clear();
  lcd.setCursor(0,1);
                lcd.setCursor(j,0);
                lcd.print("*");
                code_buff2[i]=keypressed;
                i++;
                j++;
void OpenDoor(){             //Lock opening function open for 3s
  lcd.clear();
  lcd.print("Welcome");       //With a message printed
  delay(3000);
What happens if you press all of the buttons on your keyboard? You get garbage. The code seems to be designed to be relatively robust, I suggest you cross the bridge when you come to it and simply try what ever issue you are worried about and see for yourself what will happen?
If this project is for a super duper must-be-absolutely-secure special lock then I suggest you buy a proper lock, if it's a project to try and keep the kids out of your workshop then I think you'll be okay.
JWScotSat:
This garbage make me worry :stuck_out_tongue:
I understand your point. Its meant for personal/home use but still i wouldn't like to find myself locked out of my "workshop" :slight_smile:
Haven't looked at the code.
Unless the code is already wrong, then pressing a combination of keys will be detected as pressing the wrong key - unless you determined that a particular combination of keys is the required action at some step.
But the point is moot. Either the code correctly checks for the correct key-presses, or it does not check. If it can be fooled in some way, then it is faulty code. Simple as that.
Suspect too much time spent watching MacGyver. :astonished:
Or are you asking whether the keypad library is badly written and sets more that one scan line at a time to OUTPUT so allowing you to short out pins set to OUTPUT while in opposing states by pressing multiple keys?
I don't know, can't tell since it is a library. :roll_eyes:
Paul__B:
Exactly dear friend. I also have no idea how the library works ? if it scans line by like then i guess that i will probably just be reading never ending multiple key presses. I think.
I have to "field test it" to make sure
My favorite “door” unlock method is simply one vandal resistant button and code that deciphers dot-dash entries.
Heck, skip the vandal resistant button and tie it into the doorbell button.
Some short of morse code. not a bad idea. That would require a whole different microcontroler code.
