Door programming problem in automatic operation
I took care to translate it for you
/motor + relay + LCD + cell + sensors
// LCD Keypad Shield
#include <LiquidCrystal.h>
// Create the lcd object (with the different digital ports it uses)
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//variables
int lcd_key     = 0;
int adc_key_in  = 0;
int TensionBAS  = 0; //VoltageDOWN
int TensionHAUT = 0; //VoltageUP
//constantes
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
#define RelayPin1 2 //digital port D2 is connected to relay 1
#define RelayPin2 3 //digital port D3 is connected to relay 2
#define CapteurBAS 11 // the digital port D11 is connected to the DOWN sensor
#define CapteurHAUT 12 // the digital port D12 is connected to the UP sensor
#define debugTxtVar(myParameterText, variableName) \
        Serial.print(#myParameterText " " #variableName"="); \
        Serial.println(variableName);
int Etat_fonctionnement_manuel = 0; //manual operation state
int Etat_fermeture_auto = 0; //auto closing state
int Etat_ouverture_auto = 0; //auto opening state
unsigned long temps_mesures = 0; //measures  time
unsigned long temps_fonctionnement_manuel = 0; //manual operation time
unsigned long temps_fermeture_auto = 0; //auto closing time
unsigned long temps_ouverture_auto = 0; //auto opening time
unsigned long temps_actuel; //current time
boolean JourVrai;   // ItIsDAY
boolean Test_manuel_demarrage = false; //Starting manual test
const byte manuel_Machine_inactive0 = 0; //manual_stateMachineIdle0
const byte manuel_debut_fermeture_porte1 = 1; //manual_startClosingDoor1
const byte manuel_Attendre_CapteurBAS_ferme2 = 2; //manual_waitForSensorDownClosed2
const byte manuel_Ouvrir_porte_apresTempo3 = 3; //manual_openDoorAfterWaiting3
const byte manuel_Attendre_CapteurHAUT_ferme4 = 4; //manual_waitForSensorDoorUp4
const byte manuel_arret_machine_apresTempo5 = 5; //manual_waitAndStopStateMachine5
const byte autoFermeture_attendre_tempoSoir1 = 1;//autoclose_wait_EveningDelay1
const byte autoFermeture_debut_fermeture2 = 2; //autoclose_start_closing2
const byte autoFermeture_CapteurBAS_ferme3 = 3; //autoclose_DOWNsensor_closed3
const byte autoFermeture_arret_machine4 = 4; //autoclose_stop_machine4
const byte autoFermeture_machine_inactive0 = 0; //autoclose_MachineIdle0
const byte autoOuverture_attendre_tempoMatin1 = 1;//autoOpen_wait_MorningDelay1
const byte autoOuverture_debut_ouverture2 = 2; //autoOpen_start_opening2
const byte autoOuverture_CapteurHAUT_ferme3 = 3; //autoOpen_UPsensor_closed3
const byte autoOuverture_arret_machine4 = 4; //autoOpen_stop_machine4
const byte autoOuverture_machine_inactive0 = 0; //autoOpen_MachineIdle0
  // We put the pins of each relay at the output
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(CapteurBAS, INPUT);
  pinMode(CapteurHAUT, INPUT);
  lcd.begin(16, 2);            // Screen startup
  lcd.setCursor(0, 0);         // Positioning the cursor at the start
  lcd.print("Mesure tension"); // Message
  task_mesure_tensions();
  AffichageLCD();
  lcd_key = read_LCD_buttons();  // Buttons reading
  // Outsourcing the various tasks
  switch (lcd_key)               // Action when button is pressed
    case btnRIGHT: //by pressing the RIGHT button
        if (!Test_manuel_demarrage) { // if the manual test has not already started
          Test_manuel_demarrage = true;
          Etat_fonctionnement_manuel = manuel_debut_fermeture_porte1;
  if (Test_manuel_demarrage) {
    task_fonctionnement_manuel();
  // if the solar cell detects the day and the sensor does not detect the open door
  if (JourVrai && digitalRead(CapteurHAUT) == HIGH ) {
    task_ouverture_auto(); // open door
  // if the solar cell detects at night and the sensor does not detect the closed door
  if (!JourVrai && digitalRead(CapteurBAS) == HIGH ) {
    task_fermeture_auto(); // close door
} // end of loop
void AffichageLCD() { //LCD_Display
    temps_actuel = millis();
    // Display the voltage measurement on the LCD screen and wait for 1000 ms
    lcd.setCursor(0, 1);           // Positioning of the start of line cursor
    if( (temps_actuel - temps_mesures) >= 1000ul )
        temps_mesures = temps_actuel;
        // lcd.print("L");
        if (JourVrai)
          lcd.print("jour"); //displays the value of the state of the solar cell
        else if (!JourVrai)
          lcd.print("nuit"); //displays the value of the state of the solar cell
        lcd.print(" F");
        lcd.print(Etat_fermeture_auto); //displays the value of the automatic closing status
        lcd.print(" O");
        lcd.print(Etat_ouverture_auto); //displays the value of the automatic opening state
        lcd.print(" M");
        lcd.print(Etat_fonctionnement_manuel); //displays the value of the manual mode of the door
         debugTxtVar("F=  ", Etat_fermeture_auto);
         //Serial.println(Etat_fermeture_auto);
         debugTxtVar("O= ", Etat_ouverture_auto);
         //Serial.println(Etat_ouverture_auto);
         //debugTxtVar("M= ", Etat_fonctionnement_manuel);
         //Serial.println(Etat_fonctionnement_manuel);
} // AffichageLCD
void task_mesure_tensions() { //task_Voltage_measures
  //allows you to take voltage measurements and display data on the LCD screen
  // Transforms the measurement (integer) into voltage via a cross product
  int CelluleSolaireCAN = analogRead(A1); //solarCellADC
  // Measures the voltage across the solar cell
  int MoteurCAN     = analogRead(A2);  //motorADC
  // Measures the voltage consumed by the motor
  float TensionCelluleSolaire = (float)CelluleSolaireCAN * (5.0 / 1023.0);
  // float solarCellVoltage = (float)solarCellADC * (5.0 / 1023.0);
  float TensionMoteur    = (float)MoteurCAN     * (5.0 / 1023.0);
  // float motorVoltage     = (float)motorADC     * (5.0 / 1023.0);
  if (TensionCelluleSolaire < 1.0)  //if (solarCellVoltage < 1.0)
  { // low voltage means it is starting to get dark
    if (JourVrai) { //if it is based on a day-night change of state
      JourVrai = false; //the variable changes to false when it is dark
      // start the state machine to automatically close the door
      Etat_fermeture_auto = autoFermeture_attendre_tempoSoir1;
      Etat_ouverture_auto = autoOuverture_machine_inactive0;
  else if (TensionCelluleSolaire >= 1.0) //else if (solarCellVoltage >= 1.0)
  { // high voltage means the sun is rising
      if (!JourVrai) { // if it is based on a night-day change of state
        JourVrai = true;  //the variable turns to true when it is daylight
        // start the state machine to automatically open the door
        Etat_ouverture_auto = autoOuverture_attendre_tempoMatin1;
        Etat_fermeture_auto = autoFermeture_machine_inactive0;
void FermerMoteur() { //RunMotorClosing
  digitalWrite(RelayPin1, LOW); //relay 1 is active
  digitalWrite(RelayPin2, HIGH); //relay 2 is inactive
void ArretMoteur() {//MotorStop
  digitalWrite(RelayPin1, HIGH); //relay 1 is inactive
void OuvrirMoteur() {//RunMotorOpening
  digitalWrite(RelayPin2, LOW); //relay 2 is active
void task_fonctionnement_manuel() { //allows you to activate the manual function test of the door
  // if values of a variable shall be re-used the variable must be assigned
  // global or with attribute static to keep the value even after leaving the function
  debugTxtVar("task_fonctionnement_manuel ", Etat_fonctionnement_manuel);
  //delay(1000); // slow down serial output
  switch ( Etat_fonctionnement_manuel )
    case manuel_debut_fermeture_porte1 :
      // After pressing the button, the motor turns in one direction and the door begins to close ...
      FermerMoteur();
      temps_fonctionnement_manuel = temps_actuel;//we reset the time spent to 0 ms
      Etat_fonctionnement_manuel = manuel_Attendre_CapteurBAS_ferme2; // we increment the variable by 1
    case manuel_Attendre_CapteurBAS_ferme2 :
      if ( digitalRead(CapteurBAS) == LOW  ) //when the DOWN sensor contact is closed ...
      { //... the motor pauses and the door stops for 3 seconds ...
        ArretMoteur();
        Etat_fonctionnement_manuel = manuel_Ouvrir_porte_apresTempo3; // we increment the variable by 1
    case manuel_Ouvrir_porte_apresTempo3 :
      if ( (temps_actuel - temps_fonctionnement_manuel) >= 3000ul )
      { //once the break is over, the motor turns in the other direction and the door begins to open ...
        OuvrirMoteur();
        Etat_fonctionnement_manuel = manuel_Attendre_CapteurHAUT_ferme4; // we increment the variable by 1
    case manuel_Attendre_CapteurHAUT_ferme4 :
      if ( digitalRead(CapteurHAUT) == LOW  ) //when the UP sensor contact is closed ...
      { // ...the motor pauses and the door stops for 3 seconds ...
        ArretMoteur();
        Etat_fonctionnement_manuel = manuel_arret_machine_apresTempo5; // we increment the variable by 1
    case manuel_arret_machine_apresTempo5 :
      { //return to the initial state after a 3 second pause
        Etat_fonctionnement_manuel = manuel_Machine_inactive0; // the variable goes back to 0
    case manuel_Machine_inactive0 :
      Test_manuel_demarrage = false; // manual loop finished
  }//switch
}//task_fonctionnement_manuel
void task_fermeture_auto () { //task_autoClosing
  //allows you to activate the automatic closing of the door with the brightness threshold
  switch ( Etat_fermeture_auto )
    case autoFermeture_attendre_tempoSoir1 :
      if ( (temps_actuel - temps_fermeture_auto) >= 10000ul)
      { //until the 10 seconds have elapsed ...
        Etat_fermeture_auto = autoFermeture_debut_fermeture2; //we increment the variable by 1
    case autoFermeture_debut_fermeture2 :
      FermerMoteur();
      // the door starts to close
      temps_fermeture_auto = temps_actuel; //we reset the time spent to 0 ms
      Etat_fermeture_auto = autoFermeture_CapteurBAS_ferme3; //we increment the variable by 1
     case autoFermeture_CapteurBAS_ferme3 :
      { // the motor pauses and the door stops.
        ArretMoteur();
        Etat_fermeture_auto = autoFermeture_arret_machine4; //we increment the variable by 1
    case autoFermeture_arret_machine4 :
      if ( (temps_actuel - temps_fermeture_auto) >= 3000ul )
      { //leaves the door closed and resets the variable to its initial state.
        Etat_fermeture_auto = autoFermeture_machine_inactive0; // the variable goes back to 0
    case autoFermeture_machine_inactive0:
      // nothing is happening
  } //switch
} //task_fermeture_auto
void task_ouverture_auto () { //task_autoOpening
  //allows you to activate the automatic opening of the door with the brightness threshold
  switch ( Etat_ouverture_auto )
    case autoOuverture_attendre_tempoMatin1 :
        Etat_ouverture_auto = autoOuverture_debut_ouverture2; //we increment the variable by 1
    case autoOuverture_debut_ouverture2 :
      OuvrirMoteur();
      // the door starts to open
      temps_ouverture_auto = temps_actuel; //we reset the time spent to 0 ms
      Etat_ouverture_auto = autoOuverture_CapteurHAUT_ferme3; //we increment the variable by 1
    case autoOuverture_CapteurHAUT_ferme3 :
        ArretMoteur();
        Etat_ouverture_auto = autoOuverture_arret_machine4; //we increment the variable by 1
    case autoOuverture_arret_machine4 :
      if ( (temps_actuel - temps_ouverture_auto) >= 3000ul )
      { //leaves the door open and resets the variable to its initial state.
        Etat_ouverture_auto = autoOuverture_machine_inactive0; //the variable goes back to 0
    case autoOuverture_machine_inactive0 :
  } //switch
} //task_ouverture_auto
// Button reading function
int read_LCD_buttons() { //allows you to control the buttons on the LCD display
  adc_key_in = analogRead(0);   // Reading the analog port
  // The following values must be adapted to the shield
  if (adc_key_in > 1000) return btnNONE;   // In principle 1023 when no key is pressed
  if (adc_key_in < 50)   return btnRIGHT;     // 0
  if (adc_key_in < 195)  return btnUP;        // 99
  if (adc_key_in < 380)  return btnDOWN;      // 255
  if (adc_key_in < 555)  return btnLEFT;      // 409
  if (adc_key_in < 790)  return btnSELECT;    // 640
  return btnNONE;
However, I tried to add debugoutput at the top of each state-machine like in the example, but it doesn't work. Unless I coded incorrectly ?
I also moved all the current_time variables linked to the millis () function with the global variables. I declared the variable with "unsigned long" instead of "static unsigned long".
But when I upload, I don't really see the difference.
Finally, I hope you will have no trouble reading this commented code in English.
Your posting is way too short!!
Huh! why that? From this short posting I'm very unsecure if you have understood what the meaning of the serial monitor is and how to use it.
  • You wrote nothing about what the serial monitor shows
  • you wrote nothing about your inerpretation what the output in the serial monitor might mean
This leads me to the conclusion that you have NOT looked at the output of the serial monitor at all.
You seem to have an attitude of "Stefan will do it all for me"
NO I will NOT!
You might think hey why is this guy trying to give me orders in such a strong way?
You are free to decide to react on my posts in any way.
But indeed if you want my support I rise a condition:
Post in DETAIL what you have observed in the serial monitor and what your guessing is why this is shown in the serial monitor.
I have great doubts that you even opened the serial monitor.
Post a screenshot of the serial monitor and then write YOUR interpretation of what the output means.
WRITE a SUGGESTION what you have to change in your code to make it react in the way you want it.
What you are doing until now is just following my instructions
add a line of code here
move this line of code there
and then do a new test just looking at "does it behave like I want?" reporting "No it doesn't" give new instructions.
YOU have to ANALYSE your code YOURSELF and report your GUESSINGS.
Just guessings and suggestions on how to modify it.
This process will make you LEARN instead of just executing a "command" not thinking about what it does and forget it it as soon as the modification is done.
If I remember right you run out of due next week.
It is up to you if you speed up the developing-process of your code through detailed answers
or
to slow it down in a ping-pong-game of short answers and repeated asking back for more details.
best regards Stefan
