Dot matrix display (DMD2 library)
Hello I need a little help, I need to connect 5 panels wide and two high, As I could not achieve with this library, I imagined that I could leave everything in series and leave them in 10 panels wide and one high, without results that the letters are deformed.
How can I do it?
config of panel:
Code
felipedream: Hello I need a little help, I need to connect 5 panels wide and two high, As I could not achieve with this library, I imagined that I could leave everything in series and leave them in 10 panels wide and one high, without results that the letters are deformed. How can I do it?
config of panel: |500x142
Code
Greetings,
Try change this lines:
const int WIDTH =5;
// Declarations // This sketch uses pins 2 to 9 for the outputs. int x1 = 0; // flechas posicion int y1 = 0; SoftDMD dmd(WIDTH,2); // DMD controls the entire display DMD_TextBox box(dmd); // "box" provides a text box to automatically write to/scroll the display
