Double click "Laser On" Double click "Laser Off"
Hello everyone, Thank you all for your time.
I Have my code that when I keep holding the button the laser turn on "HIGH"
when I release my finger from the button the laser turns off "LOW"
But I want when I double click the laser turn on and when I double click again the laser turn off.
Thank you and sorry for my bad English.
int laserPin = 10;
const int btn = 6;// The push button
int previousButtonStateLAZER = HIGH;   // for btn6
void setup(){
  pinMode(btn, INPUT);
  pinMode (laserPin, OUTPUT);
void loop(){
  int buttonStateLAZER = digitalRead(btn);
  // if the button state has changed,
  if (buttonStateLAZER != previousButtonStateLAZER){
    if( buttonStateLAZER == HIGH ) {
      digitalWrite (laserPin, HIGH);
    }else{
      digitalWrite (laserPin, LOW);
  previousButtonStateLAZER = buttonStateLAZER;
Thanks for using code tags. +1 karma. Do you have a question?
try the onebutton library.
try this example: OneButton/SimpleOneButton.ino at master · mathertel/OneButton · GitHub
