Double Conditional If Statement Not Working
Hello,
I have a double conditional if statement based on user input. Even when I input a correct values, the if statement considers them false when they are actually true. The if statement I am refering to in my code is the third, sub-if statement where:
if (recerveddec >= minstepsize && recerveddec <= maxstepsize)
Before I added the second condition it was:
if (recerveddec >= minstepsize)
and this worked just fine. The entire code is posted below:
// Define Constants
// User Inputs (Changes based on motor and application)
// Other constants
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean userinput = false;
int dataNumber = 0;             // new for this version
float recerveddec;
const int maxstepsize = 100000;
const int minstepsize = 1;
const int sethalfwavelength = 1000; // Set half wavelength to determine speed. Range of available speeds without abnormal vibrations: [1000,3000]. In units of (micro-secnds [10^-6])
// Connections to A4988
const int motor1dirPin = 2;  // Motor 1 direction
const int motor1stepPin = 3; // Motor 1 movement
// Connections to User Interface
const int num1controldir = 12; // Rotation direction definition pin # for motor 1
const int num2controldir = 13; // Rotation direction definition pin # for motor 2
const int motor1ID = A1; // ID pin for motor 1
  // Designate Output Pins
  pinMode(motor1stepPin,OUTPUT);
  pinMode(motor1dirPin,OUTPUT);
  // Designate Input Pins
  pinMode(motor1ID,INPUT_PULLUP);
  pinMode(num1controldir,INPUT_PULLUP);
    // Initialize serial and wait for port to open:
    Serial.println("<Arduino is ready>");
  delay(5000);
// Stepper Motor Program Begins and Loops
   recData();
   displayData();
   MoveMotor();
void recData()
   static byte ndx = 0;
   char endMarker = '\n';
   char c;
   if (Serial.available() > 0)   // If there is a serial available, read it
      // read the incoming byte:
      c = Serial.read();
      if (c != endMarker)
         receivedChars[ndx] = c;
         ndx++;
         if (ndx >= numChars)
            ndx = numChars - 1;
         receivedChars[ndx] = '\0'; // terminate the string
         Serial.println(receivedChars);
         ndx = 0;
         userinput = true;
void displayData()
   if (userinput == true)
      recerveddec = atoi(receivedChars);
void MoveMotor()
  // To control motor 1 positive movements via numerical input (Input must be an integer value)
  if (digitalRead(motor1ID) == LOW) { // ID motor 1
    if (digitalRead(num1controldir) == LOW) {
      //Serial.print("<Positive rotation for motor 1 selected> ");
      //delay(5000);
      if (userinput == true) { // If there is a serial available, read it
        Serial.print("Identified user input");
        digitalWrite(motor1dirPin,HIGH); // Set motor rotation direction
        if (recerveddec >= minstepsize && recerveddec <= maxstepsize) {
          Serial.print("Number of steps in for loop: ");
          Serial.println(recerveddec);
          for (int substep = 1; substep <= recerveddec; substep++) {
            digitalWrite(motor1stepPin,HIGH);
            delayMicroseconds(sethalfwavelength);
            digitalWrite(motor1stepPin,LOW);
        else {
          Serial.print("Number of steps must be within a range of [1,10000]!");
Yep, forgot about that detail @Delta_G. Thank you!
When conditional statements don't behave as expected it is a good idea to print the values before testing them
