double gets automatically rounded, not enough precision...
I have the following function which I need to convert some coordinates:
double convertRawToDecimal(double latOrLong){
  int decimalDegrees = (int) latOrLong / 100;
  Serial.println(decimalDegrees);
  double minutes = latOrLong - decimalDegrees * 100;
  Serial.println(minutes);
  double temp = minutes/60.0;
  Serial.println(temp);
  double result = decimalDegrees +temp;
  return result;
The important part is happening where I divide minutes by 60.
I call the method with for example 4730.59 and when I print out the temp variable which should hold something like 0.5098333 it prints out 0.51 . Now I am wondering is the println method pulling my leg or is the value stored in temp really 0.51
Thanks for helping out
multiply the number by 1000 and see how many significant digits you get.
Try:
Serial.println(minutes,4);
Note also that double & float are the same size in an arduino context; you're not getting any additional precision by specifying double.
When in doubt
When you calculate using your double it won´t round, all decimals are used for calculation.
TempleClause:
See Reply #3. The println() method is doing what it is supposed to, it is just not what you expected.
I'd like to also add that unless you have a due, there is also no difference between float and double, both have the same precision.
