Double talk.
I have boiled this down to a very simple piece of code:
int testKey;
Serial.println("Input Source ID "); //Ask me the number
while (Serial.available()==0){ } //Wait for me to answer
testKey = Serial.parseInt(); //Store my answer in this variable
Serial.print("Parsed Input is "); //Print the results on serial monitor
Serial.println(testKey);
When I run the code on my Leonardo, or Uno, I expect to have Input Source ID to be printed on the serial monitor. It remains blank (it is set to 9600 baud). If I go ahead and enter a 1, then the serial monitor starts working. However, from this point on, it seems to ask me for the ID again, and print a 0 to the serial monitor:
Parsed Input is 1
Input Source ID
Parsed Input is 0
Input Source ID
It then is waiting for me to enter a new Source ID. If I then enter a 2, this is what I get, in addition to what was already there.
Parsed Input is 1
Input Source ID
Parsed Input is 0
Input Source ID
Parsed Input is 2
Input Source ID
Parsed Input is 0
Input Source ID
My question is, why doesn't the void loop start automatically and immediately prompt me for input? Secondly, after I give it a number, it seems to run it twice, inserting a 0 into the variable. Why? This seems so straightforward, but it has me stumped. I tried some delay statements here and there, to no avail. Thanks in advance.
How fast can you type?
Please remember to use code tags when posting code.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
Also, there is a simple user-input example in Planning and Implementing a Program
...R
Are you typing, say, a "1" followed by "Enter"?
In that case, your code would return the value 1 for the digit 1 and 0 for the Enter character(s).
On the Leonardo you are supposed to have "while (!Serial);" after Serial.begin(). This is to wait until the USB connection is established. That might be why the first "Input Source ID " is lost. It is being sent before the USB connection is established. On a non-Leonardo the added line is harmless so you can put it in every sketch.
