Double variable 8 bytes
I read that DUE use "true" Double variables 8 byte.
I wish that this feature would be disposable for UNO and MEGA too.
I believe a "long long" is 64 bits, but I haven't had occasion to try them myself:
long long myInt1;
unsigned long long myInt2;
The Uno and Mega have less memory, and less program memory, so supporting double could take quite a lot of that. Bearing in mind most readings are only around 4 significant digits (eg. analog read: up to 1023), the need for 15 to 17 significant digits is probably not that great. However you can always use "big numbers":
long long works but is very slow, if it is for counting (e.g. in interrupts) one can better use a "high" long and a "low" long and when the low overflows increment the high.
Correction...
robtillaart:
long long sort of works but and is very slow
The expression is ((Value * Numerator) + (Denominator - 1)) / Denominator . Half the time the result is off by one.
If memory is a concern, [unsigned] long long division pulls in 2K worth of code.
did not encounter that but you probably have more long long experience as I have.
Added a patch for (unsigned) long long in print.cpp some time ago.
print.h
#ifdef SUPPORT_LONGLONG
	size_t println(int64_t, int = DEC);
	size_t print(int64_t, int = DEC);
	size_t println(uint64_t, int = DEC);
	size_t print(uint64_t, int = DEC);
#endif
print.cpp
size_t Print::println(int64_t number, int base)
  size_t n = 0;
  n += print(number, base);
  n += println();
  return n;
size_t Print::print(int64_t number, int base)
  size_t n = 0;
  if (number < 0)
    write('-');
	number = -number;
	n++;
  n += print((uint64_t)number, base);
  return n;
size_t Print::println(uint64_t number, int base)
  size_t n = 0;
  n += println();
  return n;
size_t Print::print(uint64_t number, int base)
  size_t n = 0;
  unsigned char buf[64];
  uint8_t i = 0;
  if (number == 0)
    n += print((char)'0');
    return n;
  if (base < 2) base = 2;
  else if (base > 16) base = 16;
  while (number > 0)
    uint64_t q = number/base;
    buf[i++] = number - q*base;
    number = q;
  for (; i > 0; i--)
    n += write((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
      'A' + buf[i - 1] - 10));
   return n;
#endif
robtillaart:
...but you probably have more long long experience as I have.
Naw. I just got "lucky".
