DoubleResetDetector with WiFiManager
Hi guys,
I need help.
I can't figure out what I'm doing wrong. DoubleResetDetector didn't work in my sketch, a goal of double-clicking on button to reset WiFi settings (motherboard ESP32).
#define BLYNK_PRINT Serial
#include <FS.h>
#include "SPIFFS.h"
#include <WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <WebServer.h>
#include <SimpleTimer.h>
#include <BlynkSimpleEsp32.h>
#include <ArduinoJson.h>
#include <Wire.h>
#include <ESP_DoubleResetDetector.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DRD_TIMEOUT 10
#define DRD_ADDRESS 0
#define ONE_WIRE_BUS 13
#define ESP_DRD_USE_SPIFFS      true
#define ESP_DRD_USE_EEPROM    true
DoubleResetDetector* drd;
char blynk_token[40] = "";
bool shouldSaveConfig = false;
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress *sensorsUnique;
int countSensors;
void printAddress(DeviceAddress deviceAddress) {
  for (uint8_t i = 0; i < 8; i++) {
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
bool initialConfig = false;
  drd = new DoubleResetDetector(DRD_TIMEOUT, DRD_ADDRESS);
  delay(3000);
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
  WiFiManager wifiManager;
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_blynk_token);
if (drd->detectDoubleReset()) {
    Serial.println("Double Reset Detected");
    wifiManager.startConfigPortal("Blynk","password");
    Serial.println("No Double Reset Detected");
    wifiManager.autoConnect("Blynk","password");
  Serial.println("wifi connected");
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
  sensors.begin();
  countSensors = sensors.getDeviceCount();
  Serial.print("Found sensors: ");
  Serial.println(countSensors);
  sensorsUnique = new DeviceAddress[countSensors];
    if (sensors.isParasitePowerMode()) {
    Serial.println("Mode power is Parasite");
    Serial.println("Mode power is Normal");
  Serial.print("local ip : ");
  Serial.print("Blynk Token : ");
  Serial.println(blynk_token);
  Blynk.config(blynk_token);
  bool result = Blynk.connect();
  Blynk.run();
  drd->loop();
Thanks a lot.
You have included an awful lot of libraries including at least one that you don't use in your code: wire.h
The code you posted is incomplete.
I don't use blynk. Tried it, didn't find it appealing for my purposes.
"Didn't work" is about as descriptive as your verbose comments. Does this line execute?
a,⸮z)⸮
⸮0⸮⸮
mounting FS...
mounted file system
reading config file
opened config file
{"blynk_token":"*************************"}
parsed json
*WM: [3] allocating params bytes: 20
*WM: [2] Added Parameter: blynk
*WM: [1] AutoConnect
*WM: [2] ESP32 event handler enabled
*WM: [2] Connecting as wifi client...
*WM: [3] STA static IP:
*WM: [2] setSTAConfig static ip not set, skipping
*WM: [1] Connecting to SAVED AP: Test
*WM: [3] Using Password: TEST123
*WM: [3] WiFi station enable
*WM: [1] connectTimeout not set, ESP waitForConnectResult...
*WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] AutoConnect: SUCCESS
*WM: [1] STA IP Address: 192.168.0.22
wifi connected
Found sensors: 0
local ip : 192.168.0.22
Blynk Token : *****************
[4061]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on ESP32
[4214] Connecting to blynk-cloud.com:80
[4566] Ready (ping: 127ms).
*WM: [3] freeing allocated params!
*WM: [3] unloading
The first two lines are a double tap:
a,⸮z)⸮
⸮0⸮⸮
And I and I don't understand, why he believes there wasn't a double-pressed button:
Thanks
Very much need your help to finish the project.
Thanks a lot.
