Doubt about root certificate expiration
Hi all,
I have some doubts about certificate expirations.
Looking at the WiFiClientSecure example for ESP32 board.
#include <WiFiClientSecure.h>
const char* ssid     = "your-ssid";     // your network SSID (name of wifi network)
const char* password = "your-password"; // your network password
const char*  server = "www.howsmyssl.com";  // Server URL
// www.howsmyssl.com root certificate authority, to verify the server
// change it to your server root CA
// SHA1 fingerprint is broken now!
const char* test_root_ca= \
     "-----BEGIN CERTIFICATE-----\n" \
     "-----END CERTIFICATE-----\n";
// You can use x.509 client certificates if you want
//const char* test_client_key = "";   //to verify the client
//const char* test_client_cert = "";  //to verify the client
WiFiClientSecure client;
  //Initialize serial and wait for port to open:
  delay(100);
  Serial.print("Attempting to connect to SSID: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  // attempt to connect to Wifi network:
    Serial.print(".");
    // wait 1 second for re-trying
  Serial.print("Connected to ");
  client.setCACert(test_root_ca);
  //client.setCertificate(test_client_key); // for client verification
  //client.setPrivateKey(test_client_cert); // for client verification
  Serial.println("\nStarting connection to server...");
  if (!client.connect(server, 443))
    Serial.println("Connection failed!");
  else {
    Serial.println("Connected to server!");
    // Make a HTTP request:
    client.println("GET https://www.howsmyssl.com/a/check HTTP/1.0");
    client.println("Host: www.howsmyssl.com");
    client.println("Connection: close");
    client.println();
    while (client.connected()) {
      String line = client.readStringUntil('\n');
      if (line == "\r") {
        Serial.println("headers received");
    // if there are incoming bytes available
    // from the server, read them and print them:
    while (client.available()) {
      char c = client.read();
      Serial.write(c);
    client.stop();
  // do nothing
If I understood correctly, the test_root_ca cert will expire, so here's my doubt:
  1. how to understand when?
  2. I will need to update the cert before it will expire, otherwise I won't be able to connect to "www.howsmyssl.com"
    Correct?
So do I need to include a sort of "cert expiration date" function in my code that will update the certificate?
Hope my question is clear enough
Save the certificate string to a file p.e. "root_ca.pem".
Check it's content:
openssl x509 -in root_ca.pem -noout -text
The output of the example is the intermediate certificate of the Let's Encrypt project:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            0a:01:41:42:00:00:01:53:85:73:6a:0b:85:ec:a7:08
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: O = Digital Signature Trust Co., CN = DST Root CA X3
        Validity
            Not Before: Mar 17 16:40:46 2016 GMT
            Not After : Mar 17 16:40:46 2021 GMT
        Subject: C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                RSA Public-Key: (2048 bit)
                Modulus:
                    00:9c:d3:0c:f0:5a:e5:2e:47:b7:72:5d:37:83:b3:
                    68:63:30:ea:d7:35:26:19:25:e1:bd:be:35:f1:70:
                    92:2f:b7:b8:4b:41:05:ab:a9:9e:35:08:58:ec:b1:
                    2a:c4:68:87:0b:a3:e3:75:e4:e6:f3:a7:62:71:ba:
                    79:81:60:1f:d7:91:9a:9f:f3:d0:78:67:71:c8:69:
                    0e:95:91:cf:fe:e6:99:e9:60:3c:48:cc:7e:ca:4d:
                    77:12:24:9d:47:1b:5a:eb:b9:ec:1e:37:00:1c:9c:
                    ac:7b:a7:05:ea:ce:4a:eb:bd:41:e5:36:98:b9:cb:
                    fd:6d:3c:96:68:df:23:2a:42:90:0c:86:74:67:c8:
                    7f:a5:9a:b8:52:61:14:13:3f:65:e9:82:87:cb:db:
                    fa:0e:56:f6:86:89:f3:85:3f:97:86:af:b0:dc:1a:
                    ef:6b:0d:95:16:7d:c4:2b:a0:65:b2:99:04:36:75:
                    80:6b:ac:4a:f3:1b:90:49:78:2f:a2:96:4f:2a:20:
                    25:29:04:c6:74:c0:d0:31:cd:8f:31:38:95:16:ba:
                    a8:33:b8:43:f1:b1:1f:c3:30:7f:a2:79:31:13:3d:
                    2d:36:f8:e3:fc:f2:33:6a:b9:39:31:c5:af:c4:8d:
                    0d:1d:64:16:33:aa:fa:84:29:b6:d4:0b:c0:d8:7d:
                    c3:93
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Basic Constraints: critical
                CA:TRUE, pathlen:0
            X509v3 Key Usage: critical
                Digital Signature, Certificate Sign, CRL Sign
            Authority Information Access:
                OCSP - URI:http://isrg.trustid.ocsp.identrust.com
                CA Issuers - URI:http://apps.identrust.com/roots/dstrootcax3.p7c
            X509v3 Authority Key Identifier:
                keyid:C4:A7:B1:A4:7B:2C:71:FA:DB:E1:4B:90:75:FF:C4:15:60:85:89:10
            X509v3 Certificate Policies:
                Policy: 2.23.140.1.2.1
                Policy: 1.3.6.1.4.1.44947.1.1.1
                  CPS: http://cps.root-x1.letsencrypt.org
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:http://crl.identrust.com/DSTROOTCAX3CRL.crl
            X509v3 Subject Key Identifier:
                A8:4A:6A:63:04:7D:DD:BA:E6:D1:39:B7:A6:45:65:EF:F3:A8:EC:A1
         dd:33:d7:11:f3:63:58:38:dd:18:15:fb:09:55:be:76:56:b9:
         70:48:a5:69:47:27:7b:c2:24:08:92:f1:5a:1f:4a:12:29:37:
         24:74:51:1c:62:68:b8:cd:95:70:67:e5:f7:a4:bc:4e:28:51:
         cd:9b:e8:ae:87:9d:ea:d8:ba:5a:a1:01:9a:dc:f0:dd:6a:1d:
         6a:d8:3e:57:23:9e:a6:1e:04:62:9a:ff:d7:05:ca:b7:1f:3f:
         c0:0a:48:bc:94:b0:b6:65:62:e0:c1:54:e5:a3:2a:ad:20:c4:
         e9:e6:bb:dc:c8:f6:b5:c3:32:a3:98:cc:77:a8:e6:79:65:07:
         2b:cb:28:fe:3a:16:52:81:ce:52:0c:2e:5f:83:e8:d5:06:33:
         fb:77:6c:ce:40:ea:32:9e:1f:92:5c:41:c1:74:6c:5b:5d:0a:
         5f:33:cc:4d:9f:ac:38:f0:2f:7b:2c:62:9d:d9:a3:91:6f:25:
         1b:2f:90:b1:19:46:3d:f6:7e:1b:a6:7a:87:b9:a3:7a:6d:18:
         fa:25:a5:91:87:15:e0:f2:16:2f:58:b0:06:2f:2c:68:26:c6:
         4b:98:cd:da:9f:0c:f9:7f:90:ed:43:4a:12:44:4e:6f:73:7a:
         28:ea:a4:aa:6e:7b:4c:7d:87:dd:e0:c9:02:44:a7:87:af:c3:
         34:5b:b4:42
As you can see, it expires next year.
  1. I will need to update the cert before it will expire, otherwise I won't be able to connect to "www.howsmyssl.com"
    Correct?
You will need to update it as soon as www.howmyssl.com uses another root certificate to sign it's server certificate. Most probably Let's Encrypt will use a new certificate before the old one expires, so that procedure makes most sense if you control the server certificate and best also CA that signs the certificates.
Sort of. Most actual root certificates are valid for about 20 years or so. As Let's Encrypt uses an intermediate certificate (that's a CA certificate signed by an actual root certificate) it would be interesting to know if the ESP32 firmware is able to handle multi-level certificate signing and can check the certificate even if only the root certificate is provided, without the intermediate certificate.
I did never test that.
