Hi... I don't have much knowledge in C and Arduino. I'm more of a curious hobbyist. I like to assemble things.
I set up a system to control the temperature of a refrigerator. Inside it has a small heater. All controlled by two relays.
Every time I start the system, both the fridge and the heater turn on. How to make them not call? My guess is to put some instruction in the void setup but since I'm not sure if it's the right place, I thought I'd ask.
Another question... In several ifs, to turn off the fridge and heater, I use the following instruction:
digitalWrite(geladeira, LOW);
digitalWrite(aquecedor, LOW);
It works on some instructions.
But in one of them, it only turns off the fridge and the heater if I do the opposite
digitalWrite(geladeira, HIGH);
digitalWrite(aquecedor, HIGH);
Why does it happen?
The complete sketch:
Controle da Fermentação
#define BLYNK_TEMPLATE_ID "xxx"
#define BLYNK_DEVICE_NAME "Controle Fermentador"
#define BLYNK_AUTH_TOKEN "xxx"
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <OneWire.h>
#include <DallasTemperature.h>
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "xxx";
char pass[] = "xxx";
#define geladeira D0
#define aquecedor D1
#define ds18b20 D2
BlynkTimer timer;
int estadoGelad = 0;
int estadoAquec = 0;
int desligaGelad = 0;
int desligaAquec = 0;
int tempo = 0;
int tempAlvo;
float histerese;
float refFrio;
float refQuente;
float tempC;
int tempoLiga;
int tempoLigaMin;
char setIntervCont;
int geladLigada = 0;
int aquecLigado = 0;
// Objeto que tratará da troca de dados com o sensor DS18B20
OneWire oneWire(ds18b20);
DallasTemperature sensors(&oneWire);
//Atualiza os pinos virtuais com os dados salvos no servidor Blynk. Importante em caso de quedas de energia/conexão
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2, V3, V9);
//Recebe comando do Blynk para ligar ou desligar a geladeira manualmente
BLYNK_WRITE(V0)
estadoGelad = param.asInt(); //Recebe 1 para ligar ou 0 para desligar
if (estadoGelad == 1){
digitalWrite(geladeira, HIGH); // Envia comando para relê ligar a geladeira
digitalWrite(aquecedor, LOW); // Envia comando para relê desligar o aquecedor
Blynk.virtualWrite(V1, LOW); // Envia comando para o Blynk desligar o botão do aquecedor manual, se estiver ligado
Serial.printf("Geladeira ligada manualmente!");
if (estadoGelad == 0) {
digitalWrite(geladeira, LOW); // Envia comando para relê desligar a geladeira
Serial.printf("Geladeira desligada manualmente!");
//Recebe comando do Blynk para ligar ou desligar o aquecedor manualmente
BLYNK_WRITE(V1)
estadoAquec = param.asInt(); //Recebe 1 para ligar ou 0 para desligar
if (estadoAquec == 1){
digitalWrite(aquecedor, HIGH); // Envia comando para relê ligar o aquecedor
Blynk.virtualWrite(V0, LOW); // Envia comando para o Blynk desligar o botão da geladeira manual, se estiver ligado
Serial.printf("Aquecedor ligado manualmente!");
if (estadoAquec == 0) {
digitalWrite(aquecedor, LOW); // Envia comando para relê desligar a geladeira
Serial.printf("Aquecedor desligado manualmente!");
BLYNK_WRITE(V2) // Parâmetro de temperatura alvo
tempAlvo = param.asInt();
BLYNK_WRITE(V3) // Parâmetro de histerese
histerese = param.asFloat();
//Se clicar no botão V5, que é só pra mostrar se a geladeira está ligada ou não, desliga novamente o botão, ou seja, não serve pra ligar a geladeira
BLYNK_WRITE(V5)
Blynk.virtualWrite(V5, LOW);
//Se clicar no botao V5, que é só pra mostrar se o aquecedor está ligado ou não, desliga novamente o botao, ou seja, não serve pra ligar o aquecedor
BLYNK_WRITE(V6)
Blynk.virtualWrite(V6, LOW);
BLYNK_WRITE(V9)
tempoLiga = param.asInt();
tempoLigaMin = tempoLiga * 60000;
setIntervCont = tempoLigaMin + 'L';
void temperatura()
sensors.requestTemperatures();
tempC = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V4, tempC); //Envia temperatura (DS18B20) para o Blynk
refFrio = tempAlvo - histerese; // Define temperatura alvo mais histerese para frio
refQuente = tempAlvo + histerese; // Define temperatura alvo mais histerese para quente
Blynk.virtualWrite(V7, refFrio); //Envia refencia para o Blynk
Blynk.virtualWrite(V8, refQuente); //Envia referencia para o Blynk
void tempoPLiga() // Quando a geladeira ligar, vai mudar tempo para 1. Esse void Vai rodar a cada setInterv minutos para voltar para 0. O void controle é rodado pelo tempo = 0
if (tempo == 1){
tempo = 0;
void controle()
if (tempo == 0){
if (tempC > refQuente) { // Se a temperatura estiver maior que refQuente, liga a geladeira e desliga aquecedor, se estiver ligado
Blynk.virtualWrite(V5, HIGH);
Serial.println("Geladeira Ligada");
Serial.print("Temperatura atual: ");
Serial.println(tempC);
Serial.print("Temperatura referência: ");
Serial.println(refQuente);
tempo = 1;
geladLigada = 1;
else if (tempC < refFrio)
{ // Se a temperatura estiver menor que refFrio, liga o aquecedor e desliga geladeira, se estiver ligada
Blynk.virtualWrite(V6, HIGH);
Serial.println("Aquecedor Ligado");
Serial.println(refFrio);
tempo = 1;
aquecLigado = 1;
void noAlvo() //Desliga geladeira e aquecedor se temperatura dentro do alvo + histerese
if ((geladLigada == 0) && (aquecLigado == 0)){
if ((tempC < refQuente) && (tempC > refFrio)){
Serial.println("Confirma geladeira e aquecedor desligados!");
void controleLigados() //Desliga geladeira e aquecedor quando ligados por ultrapassar faixa e voltarem ao alvo
if (geladLigada == 1){
if (tempC < tempAlvo){
geladLigada = 0;
Serial.print("Geladeira estava ligada... desligada! Temperatura: ");
if (aquecLigado == 1){
if (tempC > tempAlvo){
aquecLigado = 0;
Serial.print("Aquecedor estava ligado... desligado! Temperatura: ");
pinMode(geladeira,OUTPUT);
pinMode(aquecedor,OUTPUT);
Blynk.begin(auth, ssid, pass);
timer.setInterval(1000L, temperatura);
timer.setInterval(1000L, controle); //60000L
timer.setInterval(1000L, noAlvo);
timer.setInterval(1000L,controleLigados); //60000L
timer.setInterval(1000L, tempoPLiga); //60000L
Blynk.run();
timer.run();
