I'm a newbie and just got started with Arduino. I have been playing around with the book Getting Started With Arduino and felt so interesting. Though I got stumbled upon an example from that book. The circuit for the particular example is shown below.
I built this circuit and it worked perfect. Though, I was curious to know what does that resistor and the wire to ground do. So I tried removing them both and I found the circuit is working fine without those two. One behavior I observed is that, I can lit the LED by touching pin 7 with my finger, if those are not present. Can someone explain me why this is all about?
The resistor is configured as a "pull-down resistor."
subinsebastien:
If they aren't there then what is the pin connected to when the button isn't pushed? Nothing. What is the digital value of nothing? When pins are not connected to anything, they are in a "floating" state. They actually pick up noise from the environment that will flip their value at random.
Pull-Up and Pull-Down resistors force the pin to a specific value when nothing is connected to them.
subinsebastien:
Your body is a great antenna for this electrical noise.
You could take the switch to ground without the resistor though.... but look at the circuit and you'll see that without that resistor, you're actually taking the positive input from the other side of the switch straight to ground as a short circuit with no load. And that's the same as sticking the wire from the Arduino's 5V output directly into the Ground hole next to it, which will fry the thing.
(IMO, pull-up and pull-down resistors are inaptly named. It's not the resistor that's doing the pulling up or down, since you could do that with a wire and no resistor. But without the resistor it will go BOOM :0 )
That drawing shows an LED connected directly between the output pin and ground. Do not do this it will damage your arduuino. About 6 years ago pin 13 had a built in series resistor making this arrangement OK, but now it is gone. However, a lot of tutorials still contain this stupid mistake.
