Doubt regarding two millis function on single program
Hello folks,
I'm making a project where I need to calculate the media between 5 minutes of a HR-S04 sensor, and if that media is below a determinated value, it will trigger a relay that it should be in HIGH state while the media between the last minute is below other value. To prevent constant changes on switching relay state I want to use the millis function, but I already use that one to reduce the point that are saved in a microSD further on the code. I wonder if that the use of the millis() function will lead to errors regarding their different purposes. I don't have the equipment with me to test it, so I'm asking for your advice.
#define MEASURE_SAMPLE_DELAY 50
#define MEASURE_SAMPLES 6000
#define MEASURE_DELAY 250
#define MEASURE_SAMPLE_DELAY1min 50
#define MEASURE_SAMPLES1min 1200
#define MEASURE_DELAY1min 250
//interval for SDCARD writing
const int interval = 5000;
unsigned long previousTime = 0;
//interval for the cicle where that relay state can be changed
const int intervalM = 600000;
unsigned long previousTimeM = 0;
ong singleMeasurement()
  long duration = 0;
  // Measure: Put up Trigger...
  digitalWrite(TRIGGER_PIN, HIGH);
  // ... wait for 11 µs ...
  delayMicroseconds(11);
  // ... put the trigger down ...
  digitalWrite(TRIGGER_PIN, LOW);
  // ... and wait for the echo ...
  duration = pulseIn(ECHO_PIN, HIGH);
  //  Serial.print("Distancia imediata= ");
  //  Serial.print(((float) duration / USONIC_DIV));
  //  Serial.println(" mm");
  return (long) (((float) duration / USONIC_DIV));
//Funções media de 5min
long measure()
  long measureSum = 0;
  for (int i = 0; i < MEASURE_SAMPLES; i++)
    delay(MEASURE_SAMPLE_DELAY);
    measureSum += singleMeasurement();
  return measureSum / MEASURE_SAMPLES; //media  5 minutes
//Funções para media de 1 min
long measure1min()
  long measureSum1min = 0;
  for (int i = 0; i < MEASURE_SAMPLES1min; i++)
    delay(MEASURE_SAMPLE_DELAY1min);
    measureSum1min += singleMeasurement();
  return measureSum1min / MEASURE_SAMPLES1min; //media 1 minute
//function for change the relay's state
 unsigned long currentTimeM = millis();
  if (currentTimeM - previousTimeM >= intervalM) {
    if (v >= 300) {                                //if the pH is greater than or equal to 7.0
      digitalWrite(relay, LOW);                      //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
      rele = 0;
    if (v < 300) {                               //if the pH is less than or equal to 6.99
      do {
        digitalWrite(relay, HIGH);
        rele = 1;
      while {v1 < 300};
  previousTimeM = currentTimeM;
// function for writing on sdcard every 5 sec
 unsigned long currentTime = millis();
  if (currentTime - previousTime >= interval) {
    // open the file. note that only one file can be open at a time,
    // so you have to close this one before opening another.
    myFile = SD.open("TempDCDT.csv", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile) {
      //Serial.print("Writing to fa.txt...");
      myFile.print(temperature);
      myFile.print(";");
      myFile.print(v);
      myFile.print(";");
      myFile.print(v1);
      myFile.print(";");
      myFile.print(releState);
      myFile.print(";");
      myFile.print(val_a);
      myFile.print(";");
      myFile.print(hora);
      myFile.print(";");
      myFile.println(data);
      // close the file:
      myFile.close();
      //Serial.println("done.");
      // if the file didn't open, print an error:
      Serial.println("SD error");
    previousTime = currentTime;
Thanks in advance!
You can make as many sets of previousMillis and currentMillis and interval as you wish. For intervals and delays. If the loop() runs fast over and over again, and all the variables have different names, that is no problem.
If the timing is only used in the loop(), it is possible to have a single "currentMillis = millis () ; ", and use that 'currentMillis' for all the timing.
