Hello guys, I'm looking to purchase 2 TFT / LCD screens. I'm doing some research but there are always topics about library problems.
I know that there are several models (ILI9341, ILI9481, ILI9486, ILI9488, ST7735, st7796s, SSD1283A, SM_ABCDZ), but which do you recommend? Which one has more support?
What do you think of this model?
I need 2 screens, low cost, to work with esp8266 and uno.
Since we do not know what you want to use the displays for it is impossible to make an intelligent recommendation.
It may be harder to use the same LCD with both the ESOP8266 and Uno because of the different supply voltages. ESP at 3.3V and Uno at 5V.
Specify the parameters that you want and then you can try to find a display that fits your need.
Supply voltage?
Character or graphic?
Color or monochrome?
Number of pixels/characters?
Interface (8 bit, 4 bit, I2C, SPI, ...)?
Stand alone or shield?
Screen size, shape?
Library availability?
Cost?
Mr Fungus has given you a check list. All you need to do is add the answers to your message.
