I have a few doubts about some code lines in AVR
DDRB |= (1 << 0);
PORTB ^= (1 << 0);
What’s the difference between
^= and =
|= and =
&= and =
Thanks for helping me
DDRB |= (1 << 0);
PORTB ^= (1 << 0);
^= and =
|= and =
&= and =
google "^= operator c++"
so for example let me see if i could under stand
a^=b
then
a XOR b
ab a
00 0
01 1
10 1
11 0
That's it??
a|=b
a AND b
ab a
00 0
01 0
10 0
11 1
a OR b
ab a
00 0
01 1
10 1
11 1
Yes, and "a &= b;" is just equivalent to "a = a&b;", for example.
In the code lines you’ve mentioned, the intention is to modify bit0 in the registers:
^= (1 << 0) will toggle bit0
|= (1 << 0) will set bit0
&= (1 << 0) will clear bits 1-7
Thanks for the help
These are operators in the C++ programming language. Go read at a C++ tutorial - just google "cpp tutorial" and have a look at the section on assignment operators.
aurquiel:
I have a few doubts about some code lines in AVRDDRB |= (1 << 0);
PORTB ^= (1 << 0);What’s the difference between
^= and =
|= and =
&= and =Thanks for helping me
The “^” operator means “exclusive OR”, the “|” is OR and the “&” is AND.
Sticking them together with an equal sign just saves a bit of typing. For example:
this: DDRB |= (1 << 0);
means the same thing as this: DDRB = DDRB | (1 << 0);
this: PORTB ^= (1 << 0);
means the same thing as this: PORTB = PORTB ^ (1 << 0);
even this: x += 3;
means the same thing as this: x = x + 3;
Using a tilde (~) character is useful for clearing bits. For example, to SET bit 2 in a register:
REG |= _BV(2); ← see note near the bottom
To CLEAR the bit:
REG &= ~_BV(2);
You could do it the hard way and say this:
REG &= 0xFF - _BV(2);
…but why when the tilde is easier?
NOTE: “_BV(n)” is a macro which expands bit numbers to bit values. For example, “_BV(4)” means “the value of bit 4” which is decimal 32, hex 0x20.
You can use multiples ones too:
REG |= (_BV(2) | _BV(4)); // set bits 2 and 4 high
REG &= ~(_BV(2) | _BV(4)); // clear bits 2 and 4 low
