This is my first query in the forum. I am trying to build a wireless accelerometer to record vibration data. My requirements are
small size
wifi based data transmission
a 6 DOF IMU
a rechargeable battery (ex. Li-Po)
Maximum sampling/ data acquisition rate (in the range of 300-500 Hz)
I was looking for a microcontroller for the above and found nano boards with inbuilt wifi and accelerometer modules. Before procuring the items I need an expert's advice. Following are my two options:
Arduino nano RP2040: This board has wifi and accelerometer in it but lacks a battery charging circuit. Is it possible to attach an external battery (which can run it over wifi for 1-2 hrs) with a charging circuit to it? If yes then what all do I need ??
Arduino MKR wifi 1010 + Grove-6-Axis Accelerometer with Gyroscope: My second option is MKR1010 which has inbuilt wifi and a battery charging module in which it says I can attach a 3.7 v Li-Po 1800 mAh battery. But it doesn't have an inbuilt accelerometer. In that case, I am thinking of attaching an accelerometer module to it. I am not very sure will it work? Will the data sampling will be the same as in the first case?
Kindly help with your expertise.
I would personally use option number two, as you would not have to mess with battery charging circuits. Do you know if it has a battery cut off when the voltage gets too low?
Thanks, micahfriesen for responding. I was unaware of the battery cutoff. I guess it also gets activated in case you connect the board with a laptop. A power cutoff during measurements would be a definite bummer. Could you please suggest be a battery module for the second option? Also, what will be the power consumption of transmitting data over wifi in MKR wifi 1010? Suppose I want to run the experiments for 1 hrs, or 5 hrs. I want to keep the weight of the entire setup to be minimum. So want to optimize the weight with the battery backup.
Thanks jremington for replying. Actually, I do need to measure triaxial acceleration with tilt. Is Grove-6-Axis Accelerometer with Gyroscope a correct choice for that? Also, I have some doubts about the sampling frequency (SF) for the analog signals. I read somewhere that the default SF is set at 104 Hz. And some people have mentioned it can be increased with some changes in codes. Is it possible to achieve a sampling frequency of say 300 Hz for all three accelerometers?
I don't know what the power consumption for the MKR wifi 1010 is as i have never had one. A simple google search will bring up some tips on how to minimize consumption though. The reason for the battery cutoff is that if a lipo batteries can get ruined if you let them run too dead. If there was a way you could monitor the battery voltage you could make it so that you would have to charge it when it ran too dead. Like I said I am unfamiliar with that particular board, so I don't have a lot of advice on it.
Its USB port can be used to supply power (5V) to the board. It has a Li-Po charging circuit that allows the Arduino MKR WiFi 1010 to run on battery power or an external 5 volt source, charging the Li-Po battery while running on external power. Switching from one source to the other is done automatically."
Does it mean, the battery which I will be using should be 5 volts? I checked the pins, and it has 3.3v and 5 v as well.
