I'm currently working on a term paper (currently at home - because of Cororna). Txt files are to be transferred from the SD card to the PC via WiFi. I used the example "AdvancedWebServer" from library "WiFiWebServer" on a Nano 33IOT and expanded it to the extent that that a simple HTML page is opened and the file content of the SD card is listed. I find it very difficult to download the files.
The Download () function is called using the button:
void Download()
File dataFile = SD.open(server.arg(0));
if (dataFile)
server.sendHeader("Content-Length", (String)dataFile.size());
server.sendHeader("Cache-Control", "max-age=2628000, public"); // cache for 30 days
server.sendHeader("Content-Disposition", "attachment; filename=" + server.arg(0));
server.sendHeader("Connection", "close");
server.sendHeader("Content-Type", "text/text");
char buf[1024];
int siz = dataFile.size();
while (siz > 0)
size_t len = min((int)(sizeof(buf) - 1), siz);
dataFile.read((uint8_t *)buf, len);
server.client().write((const char*)buf, len);
siz -= len;
dataFile.close();
delay(5);
The browser opens the file in a new window and displays the content. But I want the file to be downloaded from the browser.
without "content-disposition" does not work either.
I'm really grateful for your help, but believe me, I've tried many versions of headers before I ask for help here in the forum.
are you sure? I have 25 years experience with this. it changed as browsers changed but Content-type: application/x-download works now more then 15 years in my java library. I use it with Content-disposition to set the file name (this works around 10 years now)
In arduino I didn't need application/x-download yet, but it should work the same way
EDIT: Check if the library doesn't set some headers too
apparently nobody can help me. Therefore I want to change my request:
Does anyone have an example code for downloading a txt file from a web server. The file is saved on an SD card. the size of the file will not exceed 10 MB.
steffi1991:
Thanks in advance
Steffi
did you try to port my SDWebServer example? 10 MB is too much. 1 MB downloads takes around 30 seconds in all libraries I tested
