"Download Sketch" does not work / "Error while downloading"
Go to a tutorial page, e.g. www.arduino.cc/en/Tutorial/AnalogReadSerial.
Scroll down to the sample code and see on the right an arrowdown symbol, saying "Download Sketch".
Click it and admire the message "Error while downloading"
Is this the intended behavior?
(I'm using Google Chrome on Win8.1 and have the Arduino IDE installed)
Thanks for posting about this michael_x! Please report this to Arduino via this form:
that will bring it to the attention of the people who are able to fix the issue.
Collecting more "Thank you for bringing this to our attention" feedback :slight_smile:
[quote author=Joyal John (Arduino Store Support) ]
I have informed the team managing these issues. Will let you know after the issue is resolved.[/quote]
Luckily it can be highlighted & copied
  AnalogReadSerial
  Reads an analog input on pin 0, prints the result to the Serial Monitor.
  Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/AnalogReadSerial
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  delay(1);        // delay in between reads for stability
