Hi guys, I'm trying to download a folder (in zip format) in my SD card using a webserver i have created. The problem is that when I click the .html of the folder it downloads a file named download.zip. When I try to open this .zip an error message comes up: "The file has an unkown format or it's damaged", but with my .CSV files it downloads and opens correctly with the correct name. Here is the specific code i use for the download:
J-M-L:
a zip is a file, not a directory not sure what you are trying to do
where is that code supposed to execute?
what is file type?
(use code tags to post code please)
Hi J-M-L , this code is supposed to execute after :
if (strstr(clientline, "GET /") != 0) { //clicked in a sub-file of root
the web browser looks like the images I have attached.
I can download .csv, .txt files, but I don't know how to download a complete folder for example : 2016/ that contains another folder (07/) and/or .csv files.
First, you are only checking file.available once. That shouldn't be an "if", it should be a "while".
// change this
if ( file.available() )
// to this
while ( file.available() )
Second, you are not closing the connection. I see no client.stop() call.
My server code handles zip ok.
http://playground.arduino.cc/Code/WebServerST
Hi SurferTim, the code you are referring to plus the original I posted would be:
if( file.isDir())
client.println("Content-Type: application/zip");
client.println("Connnection: close");
client.println();
Serial.println(F("Downloading folder..."));
char buffer[ BUFSIZE ];
int i;
for (i=0 ; (i < BUFSIZE) && (buffer[ i-1 ] >= 0) ; i++)
buffer[i] = file.read();
client.write( buffer, (buffer[i-1] >= 0) ? i : i-1 );
exit;
// reset buffer index and all buffer elements to 0
index = 0;
StrClear(clientline, BUFSIZ);
file.close();
// everything else is a 404
client.println("HTTP/1.1 404 Not Found");
client.println("Content-Type: text/html");
client.println();
client.println("<h2>File Not Found!</h2>");
delay(1);
client.stop();
NOTE: Any additional "{}" are because I have got more functions inside the loop
The question I have is if I can change the HTTP request so that it can download a full folder containing multiples .csv files (for example). Anyway I will take a look at your code, thank you.
