I'm using Arduino to control a 12 VDC linear actuator, which requires the polarity to be reversed in order to change directions. My power supply is 12V/10A. Which is a better method to reverse polarity: DPDT Relay or H bridge?
Both would work.
Better, what does this mean?
If the operation is slow and intermittent, I usually use a relay.
So the H bridge below is what I currently have set up (except with with my 12V/10A power supply) and it's not working. I'm using 2N3904 NPN Transistors. Is there any reason why this setup wouldn't work?
12V/10A power supply.
What is the resistance ?
2N3904 Absolute Maximum rating for Ic is 300ma.
20k resistors
20k resistors ? ?
What is a actuator’s resistance?
You have omitted to mention whether you require speed control.
If you only require full speed at forward or reverse, then you use two SPDT relays.
Not sure about internal resistance. Below is a link for the actuator I'm using. And speed control is not required.
