dram0_0_seg' overflowed by 206824 bytes
Wierd... worked on this for hours...
Now got errors at end of compile:
c:/users/matt/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\matt\AppData\Local\Temp\arduino_build_999641/bf2.ino.elf section `.dram0.bss' will not fit in region `dram0_0_seg'
c:/users/matt/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: DRAM segment data does not fit.
c:/users/matt/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `dram0_0_seg' overflowed by 206824 bytes
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board NodeMCU-32S.
Here is code... i'm a bit drwosty so it may be confusing
#include "esp32-hal-ledc.h"
//Define array slots by name
#define IO_ 1
#define I__ 2
#define IOT 3
#define IP -1
#define X 0
#define IN 1
#define OUT 2
int pinNo = 1;
int waveA = 2;
int waveB = 3;
int ir = 4;
int r = 5;
int g = 6;
int b = 7;
int uv = 8;
int vibrate = 9;
int len = 10;
int repeatNo = 11;
int repeatDur = 12;
int profile = 0;
int stp = 1;
int msInto = 2;
int startMS = 3;
int event = 0;
int down = 0;
int up = 1;
int maxModes = 16;
#define maxProfiles 16
#define dataSize 1024
int bfPlaying[8][maxProfiles] = { 0 };
long unsigned bfstartMS[maxProfiles] = { 0 };
int bfprofile[2][dataSize] = { 0 }; // SIMPLE event-> profiles array profile then event#
int bfNew[16] = { 0 }; //This stores the changed bf stuff
int bfData[16][4096] = { 0 }; //where the tones and flash patterns are stored
//    0         1     2    3     4  5 6 7 8   9        10      11        12
// "profile#  PinNo WaveA WaveB IR  R G B UV  Vibrate len  repeatNo  repeatDur
String bfNames[4096] = { "reserved" };
int arr16[16];
int arr1024[1024];
//**** PIN MAP ******************************************
int analogPins[16] = { 1, 3, 13, 16, 17, 18, 19, 21 }; //8 chans for now...
int pinNos32[40] = {
  1,    3,    13,     14,     16,     17,     18,     19,     21,     22,     23,
  25,   26,   27,   32,   33,   34,   35,   36,   39
int pinCapabilities[40] = {
  IO_,  IO_,  IOT,    IO_,    IOT,    IOT,    IOT,    IOT,    IO_,    IO_,    IO_,
  IO_,  IO_,  IO_,  IO_,  IO_,  I__,  I__,  I__,  I__
int installed[40] =       {
  0,    0,    0,      0,      0,      0,      0,      0,      0,      0,      0,
};//IP, X, IN, OUT
//fx prototypes
int bfEvent(int);
int bf(int);
int bfChange(int);
int arrayChangeFind(int, int, int, int);
int arrayFind(int, int, int);
  ledCstuff();
int ledCstuff() {
  for (int i = 0; i <= 8; i++) {
    ledcAttachPin(analogPins[i], i);
    ledcSetup(i, 12000, 8); // 12 kHz PWM, 8-bit resolution
  bf(0);
int bfEvent(int event) {
  //a new event
  int events[dataSize];
  //put all profiles into playprofiles[]
  int playprofiles[maxProfiles] = { 0 };
  //2 to 1 dimensional array convert
  for (int row = 0; row < maxProfiles; row++)
    arr16[row] = bfprofile[profile][row];
  for (int n; n <= dataSize; n++) {
    for (int row = 0; row < dataSize; row++)
      arr1024[row] = bfprofile[event][row];
    //count matching profiles
    int profileCount = std::count(arr1024, arr1024 + dataSize, event);
    //locate profiles for this event
    int profiles[maxProfiles];
    for (int n; n <= profileCount; n++) {
      int x = arrayFind(event, dataSize, n);
      //get profile #s... stored in profiles[]
      if (x < 0) {
        //none found
        return -1;
      int profile = bfprofile[profile][x]; //GOT profile #
      //find open playing slot
...[TRUNCATED]...
  int arrayFind(int value, int sz, int match = 0) {
    int i;
    int matched = 0;
    for (i = 0; i < sz; i++) {
      if (sz == 16) {
        if (arr16[i] == value) {
          matched++;
          if (matched == match) {
            return i;
      if (sz == 1024) {
        if (arr1024[i] == value) {
          matched++;
            return i;
  int arrayChangeFind(int sz = 16, int startAt = 0, int thresh = 0, int dirc = down) {
    //returns i of changed array value
    int intFind;
    if (sz == 16) {
      intFind = arr16[startAt];
      if (dirc == down) {
        for (int i = startAt; i <= sz; i++) {
          if (abs(intFind - arr16[i]) > thresh - 0.0001) {
            return i;
        for (int i = sz; i <= startAt; i--) {
            return i;
      return -1;
    if (sz == 1024) {
      if (dirc == down) {
          if (abs(intFind - arr1024[i]) > thresh - 0.0001) {
            return i;
            return i;
      return -1;
I'm not very experienced with the ESP32, but I'm fairly sure this means your dynamic memory usage exceeds what is available on the microcontroller. You have several massive global arrays that are eating up a huge amount of memory. I would suggest looking at whether they need to be so big and also whether you are using the smallest possible data types. Do that evaluation for all your arrays, not only the global ones.
I'm no ESP32 authority, but this:
consumes 256KB just by itself. That's half of the available RAM right off the bat.
I thought I had more RAM to work with... I suppose I could read data in stream from SPIFFS. Nodes have to sync those arrays anyhow
