system
December 29, 2011, 3:40am
1
I want to draw conductive lines on a curved rubber thing. The lines can't be any wider than 1mm each need to be thinner than 5/3 mm each; they need to be parallel each other and at 10/3 mm intervals. Graphite drawn on the rubber thing didn't seem to work.
Is there a conductive ink pen that is thin enough?
Or where can I buy conductive ink in a bottle for less than this ?
Or is there some other way I might add these lines?
Thanks
system
December 29, 2011, 5:28pm
3
bill2009:
Does it have to flex?
1mm is very narrow.
It doesn't need to flex. And yes, 1mm is quite narrow.
Caig CW100P Circuit Writer Conductive Ink Pen
Circuit Works - CW2200MTP Conductive Ink Pen, Micro Tip
system
December 29, 2011, 9:22pm
5
johnwasser:
Are you sure? I ask because adafruit suggests that the CW2200MTP is too thick.
Also, my non-math was wrong; the lines can probably be almost 5/3 mm wide. But that still is uncomfortably close to the width that adafruit reports.
5/3 mm = 1.666 mm
Adafruit says "The CW2200MTP (micro-tip pen) has an orifice size of 0.7 mm and will draw traces that average 1.5 mm in width."
Sounds like a near perfect match.
system
December 30, 2011, 3:46am
7
johnwasser:
5/3 mm = 1.666 mm
They don't report the variability in stroke width, but if it magically doesn't vary, I'd still have little room for error.
Anyway, I guess I might as well try one of these. Do you know which of the Caig CW100P or CW2200MTP is thinner?
