Hi there. I'm compiling a coding that related to touch screen and arduino mega2560(dfplayer and ds3231 too).Currently when I compile my coding, the 'drawFrame' error kept popping up and I don't know what is the problem there. it says " 'drawFrame' was not declared in this scope ". Can somebody explain what could be error be?
Im really greatful for your help since this is for my school project
thanks in advance!
here's the code.You also can point out the other mistakes i made .Thank you i do really appreciate it
#include <UTFT.h>
#include <URTouch.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
#include <DS3231.h>
#include <LiquidCrystal.h>
//==== Creating Objects
UTFT myGLCD(SSD1289, 38, 39, 40, 41); //Parameters should be adjusted to your Display/Schield model
URTouch myTouch( 6, 5, 4, 3, 2);
SoftwareSerial mp3Serial(11, 10); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
DS3231 rtc(SDA, SCL);
//==== Defining Fonts
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
extern unsigned int MusicPlayerButton[0x1040];
extern unsigned int AlarmButton[0x1040];
extern unsigned int ButtonPlay[0x1AE9];
extern unsigned int ButtonPause[0x1AE9];
extern unsigned int PreviousButton[0x9C4];
extern unsigned int NextButton[0x9C4];
extern unsigned int VolumeDown[0x170];
extern unsigned int VolumeUp[0x3B8];
int x, y; // Variables for the coordinates where the display has been pressed
char currentPage, playStatus;
int iV = 15;
int trackNum = 1;
int b = 16;
int aHours = 0;
int aMinutes = 0;
boolean alarmNotSet = true;
String alarmString = "";
float currentTemperature, temperature;
static word totalTime, elapsedTime, playback, minutes, seconds, lastSeconds, minutesR, secondsR;
String currentClock, currentHours, currentMinutes, currentSeconds, currentDate;
String timeString, hoursString, minutesString, secondsString, hoursS, minutesS, secondsS, dateS;
// Initiate display
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
// Initialize the rtc object
rtc.begin();
// Music
Serial.begin(9600); // set serial monitor baud rate to Arduino IDE
mp3Serial.begin(9600); // DFRobotDFPlayerMini
void setup();{}
setup(); ; // DFRobotDFPlayerMini myDFPlayer library which serial port to use.
delay(800); // allow time for DFRobotDFPlayerMini myDFPlayer cold boot; may adjust depending on flash storage size
void drawHomeScreen(); // Draws the Home Screen
currentPage = '0'; // Indicates that we are at Home Screen
playStatus = '0';
myDFPlayer.volume(15);//Set volume value
delay(100);
currentTemperature = rtc.getTemp();
currentDate = rtc.getDateStr();
currentClock = rtc.getTimeStr();
timeString = rtc.getTimeStr();
currentHours = timeString.substring(0, 2);
currentMinutes = timeString.substring(3, 5);
currentSeconds = timeString.substring(6, 8);
// Homes Screen
{ if (currentPage == '0')
// Checks for change of the clock
if ( currentClock != rtc.getTimeStr()) {
hoursS = timeString.substring(0, 2);
minutesS = timeString.substring(3, 5);
secondsS = timeString.substring(6, 8);
myGLCD.setFont(SevenSegNumFont);
myGLCD.setColor(0, 255, 0);
myGLCD.print(secondsS, 224, 50);
if ( currentMinutes != minutesS ) {
myGLCD.print(minutesS, 128, 50);
currentMinutes = minutesS;
if ( currentHours != hoursS ) {
myGLCD.print(hoursS, 32, 50);
currentHours = hoursS;
// Checks for change of the date
dateS = rtc.getDateStr();
delay(10);
if ( currentDate != dateS){
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.setFont(BigFont); // Sets font to big
myGLCD.print(rtc.getDateStr(), 153, 7);
// Checks for change of the temperature
temperature = rtc.getTemp();
delay(10);
if ( currentTemperature != temperature ){
myGLCD.printNumI(temperature, 39, 7);
currentTemperature = temperature;
delay(10);
// Checks whether the screen has been touched
{ if (myTouch.dataAvailable()) {
myTouch.read();
x = myTouch.getX(); // X coordinate where the screen has been pressed
y = myTouch.getY(); // Y coordinates where the screen has been pressed
// If we press the Music Player Button
{ if ((x >= 55) && (x <= 120) && (y >= 125) && (y <= 190)) {
drawFrame(87, 157, 33);
currentPage = '1';
myGLCD.clrScr();
delay(100);
drawMusicPlayerScreen();
delay(100);
// If we press the Alarm Button
{ if ((x >= 195) && (x <= 260) && (y >= 125) && (y <= 190))
drawFrame(227, 160, 29);
currentPage = '2';
myGLCD.clrScr();
// Music Player Screen
void
{ if (currentPage == '1') {
myTouch.read();
// If we press the Play Button
if ((x >= 116) && (x <= 204) && (y >= 77) && (y <= 165)) {
if (playStatus == '0') {
drawFrame(159, 121, 42);
drawPauseButton();
myDFPlayer.playTrackFromFolder(00, 001);
delay(100);
playStatus = '2';
return;
if (playStatus == '1') {
drawPauseButton();
myDFPlayer.play();
delay(100);
playStatus = '2';
return;
if (playStatus == '2') {
drawPlayButton();
myDFPlayer.pause();
delay(100);
playStatus = '1';
return;
// If we press the Previous Button
if ((x >= 45) && (x <= 95) && (y >= 97) && (y <= 147)) {
drawFrame(70, 121, 26);
myDFPlayer.previousTrack();
delay(100);
drawTrackBar();
// If we press the Next Button
if ((x >= 227) && (x <= 277) && (y >= 97) && (y <= 147)) {
drawFrame(252, 122, 26);
myDFPlayer.nextTrack();
delay(100);
drawTrackBar();
// If we press the VolumeDown Button
if ((x >= 35) && (x <= 75) && (y >= 165) && (y <= 209)) {
drawUnderline(45, 205, 65, 205);
if (iV >= 0 & iV <= 30) {
iV--;
drawVolume(iV);
myDFPlayer.decreaseVolume();
delay(100);
// If we press the VolumeUp Button
if ((x >= 230) && (x <= 280) && (y >= 165) && (y <= 209)) {
drawUnderline(235, 205, 275, 205);
iV++;
drawVolume(iV);
myDFPlayer.increaseVolume();
delay(100);
// If we press the MENU Button
if ((x >= 0) && (x <= 75) && (y >= 0) && (y <= 30)) {
myGLCD.clrScr();
currentPage = '0';
return;
// Updates the track bar
if (playStatus == '1' || playStatus == '2') {
trackPlayTime();
// Printing the clock in the upper right corner
printClock(187, 5);
// Alarm Clock Screen
if (currentPage == '2') {
myGLCD.print("MENU", 5, 5);
myGLCD.print("Set Alarm", CENTER, 20);
// Draws a colon between the hours and the minutes
myGLCD.fillCircle (112, 65, 4);
myGLCD.fillCircle (112, 85, 4);
myGLCD.printNumI(aHours, 32, 50, 2, '0');
myGLCD.printNumI(aMinutes, 128, 50, 2, '0');
myGLCD.drawRoundRect (42, 115, 82, 145);
myGLCD.drawRoundRect (138, 115, 178, 145);
myGLCD.print("H", 54, 122);
myGLCD.print("M", 150, 122);
myGLCD.drawRoundRect (215, 60, 303, 90);
myGLCD.print("SET", 236, 67);
myGLCD.drawRoundRect (215, 115, 303, 145);
myGLCD.print("CLEAR", 220, 122);
alarmNotSet = true;
while (alarmNotSet){
myTouch.read();
//Set hours button
if ((x >= 42) && (x <= 82) && (y >= 115) && (y <= 145)) {
drawRectFrame(42, 115, 82, 145);
aHours++;
if(aHours >=24){
aHours = 0;
// Set minutes buttons
if ((x >= 138) && (x <= 178) && (y >= 115) && (y <= 145)) {
drawRectFrame(138, 115, 178, 145);
aMinutes++;
if(aMinutes >=60){
aMinutes = 0;
// Set alarm button
if ((x >= 215) && (x <= 303) && (y >= 60) && (y <= 80)) {
drawRectFrame(215, 60, 303, 90);
if (aHours < 10 && aMinutes < 10){
alarmString = "0"+(String)aHours + ":" + "0"+ (String)aMinutes + ":" + "00";
else if (aHours < 10 && aMinutes > 9){
alarmString = "0"+(String)aHours + ":" + (String)aMinutes + ":" + "00";
else if (aHours > 9 && aMinutes < 10){
alarmString = (String)aHours + ":" + "0"+ (String)aMinutes + ":" + "00";
else {
alarmString = (String)aHours + ":" + (String)aMinutes + ":" + "00";
myGLCD.print("Alarm set for:", CENTER, 165);
myGLCD.print(alarmString, CENTER, 191);
// Clear alarm button
if ((x >= 215) && (x <= 303) && (y >= 115) && (y <= 145)) {
drawRectFrame(215, 115, 303, 145);
alarmString="";
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(45, 165, 275, 210);
alarmNotSet = false;
currentPage = '0';
myGLCD.clrScr();
// Alarm activation
if (alarmNotSet == false) {
if (alarmString == rtc.getTimeStr()){
myGLCD.clrScr();
myDFPlayer.setVolume(25);
myDFPlayer.playTrackByIndexNumber(1);
delay(100);
myGLCD.print("ALARM", CENTER, 90);
myGLCD.drawBitmap (127, 10, 65, 64, AlarmButton);
myGLCD.print(alarmString, CENTER, 114);
myGLCD.drawRoundRect (94, 146, 226, 170);
myGLCD.print("DISMISS", CENTER, 150);
boolean alarmOn = true;
while (alarmOn){
myTouch.read();
// Stop alarm button
if ((x >= 94) && (x <= 226) && (y >= 146) && (y <= 170)) {
drawRectFrame(94, 146, 226, 170);
alarmOn = false;
alarmString="";
myGLCD.clrScr();
myDFPlayer.stopPlayback();
delay(100);
currentPage = '0';
playStatus = '0';
myDFPlayer.setVolume(15);
drawHomeScreen();
myGLCD.setBackColor(0, 0, 0); // Sets the background color of the area where the text will be printed to black
myGLCD.print("T:", 7, 7);
myGLCD.printNumI(rtc.getTemp(), 39, 7);
myGLCD.print("C", 82, 7);
myGLCD.setFont(SmallFont);
myGLCD.print("o", 74, 5);
{ if (alarmString == "" ) {
myGLCD.print("n u h a f a", CENTER, 215);
else {
myGLCD.print("Alarm set for: ", 68, 215);
myGLCD.print(alarmString, 188, 215);
drawMusicPlayerButton();
drawAlarmButton();
drawHomeClock();
void drawMusicPlayerScreen()
// Title
myGLCD.print("MENU", 5, 5); // Prints the string on the screen
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.drawLine(0, 26, 319, 26); // Draws the red line
myGLCD.setFont(SmallFont); // Sets font to big
myGLCD.print("n u h a f a", CENTER, 215); // Prints the string on the screen
// Volume Bar
myGLCD.fillRect (78, 184, 78 + 150, 184 + 8);
myGLCD.setColor(240, 196, 30);
myGLCD.fillRect (78, 184, 78 + 75, 184 + 8);
// Track Bar
myGLCD.fillRect (48, 50, 48 + 224, 50 + 8);
myGLCD.print("0:00", 8, 48);
myGLCD.print("-0:00", 276, 48);
drawPlayButton();
{ if (playStatus == '2') {
drawPauseButton();
drawPreviousButton();
drawNextButton();
drawVolumeDown();
drawVolumeUp();
void drawMusicPlayerButton()
myGLCD.drawBitmap (55, 125, 65, 64, MusicPlayerButton);
void drawAlarmButton()
myGLCD.drawBitmap (195, 125, 65, 64, AlarmButton);
void drawPlayButton()
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPlay);
void drawPauseButton()
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPause);
void drawNextButton()
myGLCD.drawBitmap (227, 97, 50, 50, NextButton);
void drawPreviousButton()
myGLCD.drawBitmap (45, 97, 50, 50, PreviousButton);
void drawVolumeDown()
myGLCD.drawBitmap (50, 177, 16, 23, VolumeDown);
void drawVolumeUp()
myGLCD.drawBitmap (241, 175, 34, 28, VolumeUp);
// check for if Mp3 Player is stopped
bool checkFor_mp3IsStopped()
if (mp3Serial.available() > 0) {
if (myDFPlayer.getPlaybackStatus() == 0) {
return true;
else return false;
// Highlights the button when pressed
void drawFrame(int x, int y, int r)
myGLCD.drawCircle (x, y, r);
while (myTouch.dataAvailable())
myTouch.read();
void drawRectFrame(int x1, int y1, int x2, int y2)
myGLCD.drawRoundRect (x1, y1, x2, y2);
myTouch.read();
void drawUnderline(int x1, int y1, int x2, int y2)
myGLCD.drawLine (x1, y1, x2, y2);
myTouch.read();
// Sound bar
void drawVolume(int x)
myGLCD.fillRect (78 + 5 * x, 184, 78 + 150, 184 + 8);
myGLCD.fillRect (78, 184, 78 + 5 * x, 184 + 8);
// Clears the track bar
void drawTrackBar()
void trackPlayTime()
totalTime = myDFPlayer.getTotalTrackPlaybackTime();
delay(10);
elapsedTime = myDFPlayer.getElapsedTrackPlaybackTime();
delay(10);
minutes = (int)elapsedTime / 60;
seconds = (((float)elapsedTime / 60) - minutes) * 60;
playback = totalTime - elapsedTime;
minutesR = (int)playback / 60;
secondsR = (((float)playback / 60) - minutesR) * 60;
myGLCD.printNumI(minutes, 8, 48);
myGLCD.print(":", 16, 48);
myGLCD.printNumI((int)seconds, 24, 48, 2, '0');
myGLCD.print("-", 276, 48);
myGLCD.printNumI(minutesR, 284, 48);
myGLCD.print(":", 292, 48);
myGLCD.printNumI((int)secondsR, 300, 48, 2, '0');
int trackBarX = map(elapsedTime, 0, totalTime, 0, 224);
myGLCD.fillRect (48, 50, 48 + trackBarX, 50 + 8);
if (totalTime == elapsedTime) {
delay(30);
void printClock(int x, int y)
myGLCD.print(rtc.getTimeStr(), x, y);
void drawColon() {
myGLCD.fillCircle (208, 65, 4);
myGLCD.fillCircle (208, 85, 4);
void drawHomeClock() {
myGLCD.print(currentSeconds, 224, 50);
myGLCD.print(currentMinutes, 128, 50);
myGLCD.print(currentHours, 32, 50);
drawColon();
-actually i copied the code from somewhere and i change it a little since the used device arent same
