Drawing part of a bitmap only
Hello everyone.
After some searching i has unable to find any code to draw only a part of a bitmap using the UTFT library.
In my desperation i have make a crude function that will do this for me.
The function will redraw any portion of a bitmap rather that redrawing the entire bitmap.
I am sure this will be usable in many applications.
the code and a demo is shared below and is free to use and modify. code is also available as a zip.
please share all improvements on this thread so that it may be developed to work for everyone.
Please note that the demo was developed on a CTE70 display in 800 * 480 resolution in portrait orientation.
I also used an arduino due on ide 1.5.5.
you will need to use the UTFT library from henning karlsen. Electronics - Henning Karlsen
code is here, uploads to the forum is FULL.
// redraw bitmap function by ewan van teijlingen
// january 12 2014
#include <UTFT.h>
UTFT          myGLCD(CTE70,25,26,27,28);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.clrScr();
// Dimensions    : 200x120 pixels
// Size          : 48,000 Bytes
unsigned short Background[0x5DC0] =
// insert image array of 200 * 120 here or download the code from the hyperlink above
void DrawBackground (int OriginalHPos, int OriginalVPos, int ImageSizeH, int ImageSizeV, unsigned short data[], int Scale, int ScreenHSize, int ScreenVSize, int HStart,int VStart,int HStop,int VStop)
unsigned short TempBackgound[0x1E0];
    VStart = map(VStart, 0, ScreenVSize, 0, (ScreenVSize / Scale));
    VStop =  map(VStop,  0, ScreenVSize, 0, (ScreenVSize / Scale));
    HStart = map(HStart, 0, ScreenHSize, 0, (ScreenHSize / Scale));
    HStop =  map(HStop,  0, ScreenHSize, 0, (ScreenHSize / Scale));
    for (int I = VStart ; I < VStop ; I++)
      int Count = 0;
      for (int K = ((I * (ImageSizeH)) + HStart) ; K < ((I * (ImageSizeH)) + ((HStop - HStart) + ImageSizeH)) ; K++)
        TempBackgound[Count] =  data[K];
        Count++;
    myGLCD.drawBitmap( OriginalHPos + (HStart * Scale), OriginalVPos + (I * Scale), (HStop - HStart) ,1 , TempBackgound,  Scale);
DrawBackground(0,0,200,120,Background,4,800,480,0,0,800,480);
DrawBackground(200,120,200,120,Background,2,800,480,0,0,400,240);
DrawBackground(300,180,200,120,Background,1,800,480,0,0,200,120);
myGLCD.setColor(VGA_GREEN);
myGLCD.fillRect(350,200,450,240);
DrawBackground(300,180,200,120,Background,1,800,480,20,20,180,100);
DrawBackground(200,120,200,120,Background,2,800,480,50,60,350,180);
DrawBackground(0,0,200,120,Background,4,800,480,200,120,600,360);
myGLCD.setColor(VGA_RED);
myGLCD.fillRect(0,240,800,480);
DrawBackground(0,0,200,120,Background,4,800,480,0,240,800,480);
myGLCD.fillRect(300,240,500,360);
DrawBackground(200,120,200,120,Background,2,800,480,0,120,400,240);
Hoi Ewan.
You forgot to attach your code or a link to it.
use the HYPERLINK BUTTON to add links (second row, 3rd from the left)
