Drifting PPM Signal for RC
Hello,
I am trying to generate a PPM signal for a drone to mimic what come out of an RC receiver. I got it working, but channel 1 is drifting within its window from 1000 - 2000. I attached a graph to show you what channel 1 looks like. All the other channels are rock solid. Does anyone have an suggestions on how to fix this?
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define chanel_number 11  //set the number of chanels
#define default_servo_value 1500  //set the default servo value
#define PPM_FrLen 22500  //set the PPM frame length in microseconds (1ms = 1000µs)
#define PPM_PulseLen 300  //set the pulse length
#define onState 1  //set polarity of the pulses: 1 is positive, 0 is negative
#define sigPin 10  //set PPM signal output pin on the arduino
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
int buttonState = 0;
int ppm[chanel_number];
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  for(int i=0; i<chanel_number; i++){ //initiallize default ppm values
    ppm[i]= default_servo_value;
  pinMode(sigPin, OUTPUT);
  digitalWrite(sigPin, !onState);  //set the PPM signal pin to the default state (off)
  cli();
  TCCR1A = 0; // set entire TCCR1 register to 0
  TCCR1B = 0;
  OCR1A = 100;  // compare match register, change this
  TCCR1B |= (1 << WGM12);  // turn on CTC mode
  TCCR1B |= (1 << CS11);  // 8 prescaler: 0,5 microseconds at 16mhz
  TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
  sei();
  if (radio.available()) {
    radio.read(&buttonState, sizeof(buttonState));
    if (buttonState == HIGH) {
      ppm[10] = 1990;
      delay(250);
  else {
      ppm[10] = 1000;
  ppm[2] = 900;
  Serial.println(ppm[10]);
  static int val = 1;
  ppm[0] = ppm[0] + val;
  if(ppm[0] >= 2000){ val = -1; }
  if(ppm[0] <= 1000){ val = 1; }
  delay(10);
ISR(TIMER1_COMPA_vect){  //leave this alone
  static boolean state = true;
  TCNT1 = 0;
  if(state) {  //start pulse
    digitalWrite(sigPin, onState);
    OCR1A = PPM_PulseLen * 2;
    state = false;
  else{  //end pulse and calculate when to start the next pulse
    static byte cur_chan_numb;
    static unsigned int calc_rest;
    state = true;
    if(cur_chan_numb >= chanel_number){
      cur_chan_numb = 0;
      calc_rest = calc_rest + PPM_PulseLen;//
      OCR1A = (PPM_FrLen - calc_rest) * 2;
      calc_rest = 0;
    else{
      OCR1A = (ppm[cur_chan_numb] - PPM_PulseLen) * 2;
      calc_rest = calc_rest + ppm[cur_chan_numb];
      cur_chan_numb++;
For clarification, you are not talking standard servo output, where you would use a separate pin for each servo.
You are talking about the protocol where all the channels are put on to a single pin.
Right?
If I were trying to troubleshoot this, I would want to remove all the other pieces and just include the bare minimum for reproducing the problem.
Take out everything that does not produce the signal you want to test. Put in fixed values for the channels and see what your code produces.
Maybe have your code alter the channel values in a similar way to what the servo sweep does.
Do you see that same output on your signal?
Yes, I am talking about the protocol where all the channels are put on to a single pin.
I finally found time to strip down the code and do a test again and found the same problem. The first channel is drifting exactly the same as it was in the first post. Any ideas on how to clean this up?
#define chanel_number 6  //set the number of chanels
  cli();
  TCCR1B = 0;
  sei();
  static int val = 1;
  delay(10);
  TCNT1 = 0;
    state = false;
    state = true;
      cur_chan_numb = 0;
      calc_rest = 0;
    else{
      cur_chan_numb++;
