Drive a nixie tube
Hi!
Which transistor do I need to drive a IN-4 nixie tube? I just need to switch 3 different numbers with 170V voltage. It would be best if I could use simple transistors, no need for an IC
-tsaG
EDIT: Done! I found the MPSA 42 transistor which is capable to drive 300Vv :slight_smile:
Remember the correct load resistor on the anode, check the correct value for your particular tube and power supply voltage.
