Hello here,
I try to drive a shutter (230VAC motor).
When no load is connected to the relays, everything works smoothly. But when I connect the load (my shutter), after a random number of relay switch (often just 1), the microcontroller freezes and never comes back to normal. I need to switch power off and on to make it start again.
I was initially thinking of Brown-Out Detection fuse being wrongly set, but after every failing switch, the uc would have reset by itself, nah? Then I found the following threads:
https://forum.arduino.cc/index.php?topic=420681.0
https://forum.arduino.cc/index.php?topic=438174.0
https://forum.arduino.cc/index.php?topic=117438.0
They all mention switching noise in relay driving AC load, that disrupts nearby electronics.
Mentioned solutions are:
- a MOV installed between NO and COM contacts => would need some explanation
- a snubber across the AC load => same
- solid state relay (I try to drive a 230VAC load)
- opto isolation (would require two separate power)
What solution should I choose in my situation?
Maybe I made something wrong designing my board or choosing my components, can you advice?
You'll find attached my schematic and board.
Thanks in advance for your help,
Nicolas
