i want to drive dc motor using class d chopper , so i need the dc motor some times work as motor to lift up the load , and when it reach the top stop some seconds and then, work as generator and the load came down again …
So when we want the dc motor operate as motor or generator using class d chopper (it use two switches and two diode) to control the voltage across each switch using arduino ,
this is first time for me to using arduino can any one helps me in this code ?
Much easier to get an H-bridge driver (4-quadrant, not 2), they are readily available.
Sounds like you'll need position control to hold-position under load.
Note that if lots of power comes back in generation mode the supply needs to be
able to handle that back-feeding (rechargable batteries can do this, most other
supplies cannot and simply over-voltage and the result is destruction of driver or
supply)
Commercial motor drivers typically have a big resistor and a special extra switch-mode
circuit to route back-fed energy into the resistor to prevent the voltage rail rising.
